No sound from bose 321 or tv - Televison & Video
djSilver
  • 10 Answers
SOURCE: BOSE 321
Have u tryed other disc ? if so your Bose system my have read a corrupted disc u may want to change out your IDE cable and if that doesn't work then corrupted files has made its way to one of your main broads.
Posted on Apr 24, 2008
SOURCE: surround sound
no resolution
Posted on Jun 04, 2008
  • 623 Answers
SOURCE: hooking up bose 321 to my tv
I am about to go through the same process. I have a Bose 321, and am on the verge of getting a HDTV. From what I can figure, the Bose can play a dvd and input it to the HDTV via video and audio output plugs off the back of the Bose to the audio/video input jacks on the back of the new HDTV. I think individual cables will have to be run for each. They usually are red or white, sometimes green or blue. I am sure everyone has seen these in their life. The Bose 321 technology only had what was called an S-Video cable output for the best picture, which is how my current tv gets it's Bose signal, but now HDMI seems to have superceded S-Video. Therein lies an obstacle to be overcome.
Posted on Jan 29, 2009
  • 16 Answers
SOURCE: I have a Vizio P42HDTV10A with a Bose 321 system and no sound
Check you cables. make sure that the Dish Box is hooked up and if you are run'n your cables from the Dish Box to the DVD player then you will have to keep the player on.
Use to work for DirecTV i got this all the time
Posted on Aug 25, 2009
  • 8 Answers
SOURCE: connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Posted on Sep 12, 2009
Bose 321 device code for Kogan UHD TV
Your Bose remote may not work with your Kogan TV.
Aug 12, 2016 | Bose 321 GS series II
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
321System No sound just humming with TV connected to Video1 or 2
Hi...
Get new audio cables . It seems there's a broken Ground (shield ) wire somewhere in the cable. NO ground means HUM usually
Dec 30, 2008 | Bose (321GS) System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
