Question about Sony 900 Mhz Babycall Nursery Monitor Ntm 910
I've lost the instruction manual for my baby monitor, the version i have is slightly different than the one pictured here (it's tan and white the "900 MHz Baby Call Nursery monitor with 2 receivers) ...my problem is 1 i dont know if it is set up correctly because there is this "tapping/knocking" sound that comes through the receiver loudly enough to drowned out the sound of the room my child is in. have i done or set something up wrong?
SOURCE: Sony Bravia KDL 52XBR-4
FXFVX
Posted on Apr 02, 2008
welcomejee
  • 10594 Answers
SOURCE: I bought a Sony STR-DE585 5.1 Receiver about 6
Click Sony Support and download copy of Instruction Manual of your receiver. Hope this will help you to set it up.
Posted on Mar 16, 2009
SOURCE: working the Sony STR-DE475 5.1 Channels Receiver
It has a dedicated sub out. you need a phono connection on one end for the amp and the other end must have a compatable connection to your sub.
You will need a phono connection to the amp from your TV. You can utilise a scart lead that has phono outputs however a TV with audio outs (the red and white leads) is the default option.
Posted on Jun 02, 2009
larry james
  • 287 Answers
SOURCE: No sound coming from Sony Receiver STR-DG510?
Sounds like you are pretty close with this one. If you select fm tuner do you get audio. If not you may have the speakers on the wrong a-b setting. Make sure the audio from your cable box is not muted or turned down.
Posted on Jul 15, 2009
  • 148 Answers
SOURCE: My v7 lcd monitor just went off and wont come on
Hit here, check the capacitors first, the most common problem in tv/monitors nowadays!The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you(or not)please rate, thank you!ec30db3.jpg
Posted on Feb 04, 2010
It seems that my new Desktop PC encounter problems every time the screen is not used for 30 minutes or more. I have a Samsung SyncNaster 2033 monitor and a 1GB DDR5 HD5670 SAPPHIRE Graphic Card.
The computer is most likely going into a sleep mode after 30 minutes, normally you can wake it up by simply moving the mouse, or pressing a key on the keyboard. If the sleep mode is malfunctioning, which is sometimes the case, you can disable it by clicking start, then control panel, then power options, and on the left hand side you should see 'choose when to turn off the display'. It varies slightly for different versions of windows, but what you're looking for will be in the control panel under something mentioning power. The instructions I've given are for windows 7
hope this was helpful.
May 30, 2011 | Samsung Syncmaster 2033SW Monitor
Safety 1st High Def Video monitor screen white
You can call this number : (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays
Thank you
May 03, 2010 | Safety 1st Baby View Black & White Video...
Lost instructions
http://www.silvercross.co.uk/Download.ashx?id=3631 is the link for the Silvercross 3D pram system manual, however the main page can be found at
http://www.silvercross.co.uk/contact/instruction-manuals/
(slightly different from the above!)
Regards
Paul
Dec 11, 2008 | Silver Cross 3D Carriage Stroller
Sony 900 Mhz Babycall Nursery Monitor Ntm 910 Logo
57 people viewed this question
Top Sony Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Sony Baby Gear Expert? Answer questions, earn points and help others
