Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Installation when placing hard drive into slot cannot get side straps to connct into place on both sides AND when it is placed all the way down into the slot area the computer basically goes down and will not come back up
  • drnvijaysu May 11, 2010
    plz give me installation software for 98 win ii editon
Please give me kingston pen drive driver
Posted on Oct 23, 2008
Installation
On a desktop computer
wear an antistatic earth strap remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these
then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
utube video install a second ide hard drive
http://www.fonerbooks.com/laptop_1.htm
laptop hard drive
http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html
hope this helps
Nov 22, 2012 | Seagate Computers & Internet
How to take the hard drive out
on a desktop computer
Oct 14, 2012 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Howtosetup
not sure what you want to install whether an operating system or a hard drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
laptop hard drive
hope this helps
Jul 25, 2012 | Computers & Internet
Car seat base is still wobbly after installed in the car. We don't have specific instructions for it. Can you email directions for the proper installation?
Good Day!
Here are two videos that will simply shows the proper way to install it.
and
http://www.ehow.com/video_4440636_use-infant-car-seat-bases.html
Here are some tips for added protections on your car seats
  • Many times this type of car seat comes with a base that a carrier latches into. This actually makes installation easier because you are dealing with a rather small piece of plastic. The base and carrier should only go in the back seat, preferably in the middle, although this is not a hard-and-fast rule.
  • You might need to place a shortened swimming noodle (one of the only materials CPS has certified) to level out the base, which should lie at a 45-degree angle with the carrier installed. Some manufacturers make bases that are adjustable.
  • Make sure the carrier straps are tight and the harness clip is even with the baby's shoulders or armpits. Also make sure the straps are in the slot that lines up just above or closest to the infant's shoulders.
  • If the child is still a bit wobbly in the seat due to her size, place rolled receiving blankets or towels along each side. This provides additional support and cushion. However, do not place anything under the harness straps.
  • When the carrier is snapped into the base, the handle should be out of the way. Place it in the down position.
  • Some older vehicles (especially those manufactured prior to 1997) may require the use of a locking clip. This is a small piece of metal that looks like the letter "I" on its side. Certain vehicles do not have seat belts that lock when the brakes are slammed. The clip locks the seat belt and prevents extra slippage in the event of an accident.
Aug 28, 2011 | Toys
How to remove hardrive from ml3109
Turn the laptop so the bottom is facing up. Make sure you have powered the laptop off and have unplugged the AC adapter and battery. Near the part labeled E there are two small phillips screws. You would need to remove those and the tray at location E will pull out with the hard drive attached. There will be 4 screws(two on each side) holding the hard drive onto the tray, remove those and the hard drive can now be taken out. Reverse the steps using the new hard drive.
Mar 05, 2011 | Gateway Computers & Internet
I need a video tutorial on how to replace the CD-ROM drive in the Fujitsu Siemens Amilo Pro V2010.
All you need to do is leaver off the power button strip with a thin screwdriver. The power button strip has a slight gap at each side this is where you insert the thin screwdriver or thin leaver.
The power button strip has two plastic locking down lugs at each side they hold it in place.
Do it from the power on button side first with the screen flat backwards or you will pop off some keys.
Getting off the power button strip is the hardest part without poping off keys or scratching the case.
Unscrew the single silver screw to release the key board this screw is located slightly to the right of center although there are four locking down tabs on the keyboard it is only held down in the second one from the right. (It’s the longest screw in the laptop)
Push the keyboard slightly forward then tilt the keyboard towards you and lay flat (you should have enough strap to do that)
If you want to remove the keyboard completely you have to lift up the left and right lug each side of the strap)
Just at the right top edge of the strap connector you will see a silver headed screw, remove it.
The CD/DVD writer is now free however at the end nearest to you it is pushed into its electrical socket which is part of the motherboard.
If you press on the silver metal bit that you removed the screw from (looks a bit like a top chopped off triangle) the writer will slid out of its electrical socket, the device will come out from the right side of the laptop.
Remember if you are replacing the writer you will have to get one with the correct electrical socket.
Replacement is the reverse of removal. Slid in the DVD writer make sure it slots into the electrical socket. Put the locking screw back in. Locate the keyboard in its forward slots and slide in the strap, lock it into its connector, by pushing down the lugs either side. Lock down the keyboard with its screw and push back into place. Push the power button plastic strip into place.
Do the operation with the battery out and the power adaptor disconnected.
Hope this is clear enough and helps.
Feb 16, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Physical installation of 2nd hdd
The document below gives instruction for installing, but the place and shape of the cabinet and hdd case may be different from you PC. You can use this as a refrence. Installing a hard disk drive Use the steps in this section to install a new hard drive into an empty drive bay. Step 1
If you are installing a new hard disk drive, make sure it is set to cable select. c01179815.jpg Step 2
Slide the hard disk drive into the hard drive cage. c01196498.jpg Step 3
Align the screw holes on the hard drive with the screw holes on the hard drive cage. c01179817.jpg NOTE: Make sure the connectors are at the top of the hard drive cage. c01179818.jpg Step 4
Replace the four screws (two on each side) to secure the hard drive to the hard drive cage. c01179813.jpg Step 5
Connect the power and data cables to the drive. The connectors are keyed and can be attached in only one way. c01179809.jpg Step 6
Insert the hard drive cage into the PC.
Align the four tabs on the side of the hard drive cage with... c01179819.jpg ... the four slots inside the PC. c01179820.jpg Align the three tabs on the side of the hard drive cage with ... c01179821.jpg ... the three slots on the front of the PC. c01179822.jpg Step 7
Slide the hard drive cage down until it snaps into place. c01196499.gif NOTE: Make sure the front tabs on the hard drive cage are correctly inserted into the slots on the front of the PC. c01196500.gif Step 8
Replace the two screws that secure the hard drive cage to the PC. c01179804.jpg Step 9
If you are adding another hard drive instead of replacing a hard drive, connect the SATA data cable for the new hard drive to the next available SATA connector on the mother board.
NOTE: The SATA data connectors on *********** board may look slightly different than the example. c01833532.gif Step 10
Replace the front panel and the side panel, and then reconnect the cables.
For more information about replacing the side panel and the front cover, refer to the HP support documents Removing the Front Cover and Opening the PC Case . c01179827.jpg Step 11
If using Windows, wait until Windows finds and configures the new drive. c00615034.gif
Regards,
Shrey
Oct 07, 2009 | Computers & Internet
Need to replace the hard drive
Very easy to do. You will need an antistatic wrist strap. Unscrew the screw/thumb screws on the side of the case which slides off. slide the case door off, connect your anti static wrist strap to you and a metal part of the case, to ensure you are grounded and don't fry any parts. Check what sort of hard disk your motherboard supports, it could be IDE or Sata. Older ones use IDE. Get a hard disc to match and plug it in where your old hard drive was. The hard drive is probably held in by clips or screws. remove them and place the new hard drive in the hard drive bays. Wire it up. You will need to install an operating system on your new hard drive. This can be done by getting a windows boot cd, entering the bios on startup by hitting the delete or f12 key/ the specified key. Then in the bios go to boot device priority set it to CD. Then reboot and it will install it on your new hard drive. Hope that helps.
Aug 16, 2009 | Dell Dimension 2300 PC Desktop
How do i place the seat on the bugaboo cameleon?
Are you talking about the seat fabric and putting it onto the frame?
Remove the handle bar and the metal pole from the seat frame legs to relaxe frame, put seat fabric ontop top of seat frame and fit. place one strap onto the pins at side with holes then turn seat frame onto side. use foot and weight to bring the other strap over the pins and slot into holes fasten buckle undernethe and the velco tabs.
Jun 05, 2009 | Bugaboo Cameleon Jogger
Shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
32 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
