Question about Fisher CD-RW1000 2-Disc CD Recorder
When I put put a blank CD in record side and push record it tells me no CD-DA-D2. The recorder is set for analog and receives an input signal from Dish Network.
    Brigadier General:
  • 8,546 Answers
It probably means you're trying to record on a data CD, not a Digital Audio (DA, get it?) CD.
Posted on Apr 03, 2011
Vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
D- IN UNLOCK on my display and it wont let me record, how do i fix this?
This happen when you have the setting for Digital when the analog signals are input. It is telling you the sync signal expected by a digital input is not there. I have seen this many times and it is just a setting of input not a malfunction of the unit.
Jan 14, 2013 | Tascam Cd-rw900sl Cd Recorder/player
On some blank cd's I get a DA:D2 can't record
I'm told this is the manual...
http://support.radioshack.com/support_audio/doc71/71337.pdf
Page 28
The quick answer is that you're trying to use a blank Data CD on a consumer AUDIO recorder. No can do.
This is true for ALL consumer audio CD recorders. Buy blank media that has Audio or Music printed right on it.
Feb 20, 2011 | Fisher CD-RW1000 2-Disc CD Recorder
I want to use the optical input s a dac without going through the recorder
Put in a blank or unfinalized disc, press Record until Record Manual shows. This is similar to an old-school cassette deck being in Pause/Record mode. That should do it. The input signal will be present on the audio outputs (both digital and analog).
The manual isn't specific about how long you can remain in Record Manual mode without starting to record on the CD. My Pioneer has a Monitor function so I don't need to place a blank disc for this.
Jan 03, 2010 | Philips CDR870 CD Recorder
No audio for DVD/CD inputs
Has the DVD settings been altered so that it's now putting out an analogue signal?
Jul 01, 2017 | Harman Kardon AVR 430 7.1 Channels...
Problem with analog recording on Yamaha CDR D651
Your assessment that it duplicates CD's internally fits with an analog-only failure mode. Let's make sure the signal is getting past your RCA jacks on the deck...
Put the deck in a Rec/Standby mode and make sure an analog source registers adequate volume on the meters. If it's good there and doesn't change with cable swapping between the input channels, you're right, the problem is internal. Maybe the volume potentiometer itself has developed a dead spot. Manually rotate it throughout its range many times to wipe it clean.
If you have an external optical digital source use it to check the meters in digital recording mode to be sure they're about even. The same knob affects analog and digital levels.
If you have the deck connected via the traditional Tape Monitor circuit in a receiver you should be able to tell by ear if the one channel is dead or too low. This puts all of the recording circuitry including the volume knob in line with your receiver.
May 16, 2009 | Yamaha CDR-D651 2-Disc CD Recorder
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Teac rw-cd22 burning problem
You were right! I changed the cd and it does not do DA:D2
Feb 13, 2008 | Audio Players & Recorders
Fisher cd-rw1000
ah..yes..mi friend, i was in that spot one time. one suggestion i have is-make sure the blank cd you are trying to record on is a "compact disc DIGITAL audio"...or try hitting the "input select" button.
Feb 08, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Fisher CD-RW1000 2-Disc CD Recorder Logo
140 people viewed this question
Top Fisher Audio Players & Recorders Experts
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
