The auto stop on my Royal VF850MX paper shredder won't turn off. I was using it and it was fine. Now it won't turn off automatically.
I took my Royal HG120 apart and cleaned it good. Now the auto shutoff works fine. The Royal has 6 screws that I removed (make sure it's unplugged) and then vacuumed it out and then took a q-tip and rubbing alcohol and cleaned the sensors that are located in the middle of where you insert a piece of paper. I was surprised at how much paper was amongst the electrical parts. Perhaps I shouldn't use a bag... just the plastic container. The bag may push paper into place it shouldn't be. I also should empty it more often and not try shoving the paper down to get just a couple more pieces of paper shredded. Good luck!
Posted on Oct 16, 2011
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
Won't shut off
You have an optic sensor that is blocked or shorted. If you take it apart you should be able to identify the problem. It is up by where the paper feeds in.
Jan 08, 2013 | Royal 1610X Shredder
The shredder has stopped working for either CDs or paper. The green light comes on when the switch is set "auto", but it won't shred
Is it Jammed.??? does the motor at least run.????
If the motor runs but the cutting blades dont turn then youv'e lost a gear inside....if the motor dosn't turn at all...then youv'e prbably lost the PCB inside...also make sure youv'e cleaned the Glass eyes in the middle of the paper oening....for parts give Royal a call at 1-800-524-0799.
Aug 30, 2010 | Royal VF1000MX Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
How to set to automatic stop.
In the Auto position it should stop by itself after the paper has passed thro...if it is not stopping try cleaning the "glass eyes" in the middle of the paper opening.( unplug the machine first.)
Feb 12, 2010 | Royal 1610X Shredder
My Royal VF700 shredder will not turn off
Try giving the EYES in the middle where you insert the paper a clean...if that dosnt work you may have lost the pcb inside ...give Royal a call at 1-800-524-0799 for parts assistance.
Feb 24, 2009 | Royal VF700 Cross-Cut Shredder
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Jun 14, 2007 | Royal VF1012mx Shredder
197 people viewed this question
jasbo
jasbo
