Question about Hitachi Televison & Video
My TV won't turn on I have unplug it and plugged it back in but it won't turn on.
  • shortymoore1 Apr 03, 2011
    There is no red light, what happened when I plugged it back in a blue light came on for a few sec and than nothing. The model is Hitachi 55VS69A
  • Hitachi Master
  • 2,098 Answers
May I know if it has a led light in the front panel or totally dead seat. And if you can give us the brand and model of your tv much better to assist you further.
Jdvillanueva
Posted on Apr 03, 2011
  • Jdvillanueva
    Jdvillanueva Apr 03, 2011
    This is an indication of out-of-regulation in the power supply section. The very
    common caused of this fault was the dried-up/leaky electrolytic
    capacitor
    in that section. It
    will drop the supply from normal voltage and
    will disable the unit. Sometimes it has a bulged/dome at the top but not all, it is better
    that you have a capacitor
    checker/tester
    to determine
    its condition. Also, bad
    solder joints
    can produce the
    same symptom, it is hard to spot, you should use table lamp/portable lamp for
    finding the cold solder. Another reason of fault was a missing output supply which caused open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor,
    shorted zener diode(all
    are in the power supply section) and the microcontroller.
    Best that you check the output voltage of each regulator to determine where the
    fault came from and narrow the job.
    If you don't have necessary tools
    and test instruments
    , and can't do the job yourself, I would advice you to
    look for a professional to troubleshoot the problem. Don't
    attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored
    electricity enough to hurt you with a little mistake only.
    Also check if your unit is under warranty /extended warranty,
    avail it because the manufacturer of your unit will fix it for free. Don't open
    the back panel, this will void the warranty.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
    This is an indication of out-of-regulation in the power supply section. The very common caused of this fault was the dried-up/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Another reason of fault was a missing output supply which caused open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
    If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
    Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
    Hope I helped you.
    Have a nice day!
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
TV won't come back after pushing wrong button on remote.
Try unplugging the TV.. After you plug it back in it may be OK. I had a similar problem were I could not turn on the TV (JVC). The owners manual specified in the troubleshooting section to unplug for 1/2 hour. I left it unplugged overnight and the next day plugged it in and it was fine.
May 21, 2013 | Televison & Video
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Who is liable for s replacement tv if electrical company turns power off and on during a storm and the tv won't come back on?
have you unpluged the power from the tv and the outlet for a few minutes? then plugged it back in?
Jul 25, 2011 | Sanyo Televison & Video
My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
May 18, 2011 | Sony Televison & Video
TV won't turn on
Hi There,
Try unplugging the TV and wait 5 minutes, plug it back in. Let me know what happens.
Mar 29, 2009 | RCA Televison & Video
Televison & Video Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
