Question about Goodman Heating & Cooling
What is the heat rise for gks90703bxag gas furnace
  • 40 Answers
The heat rise is on the rating plate but should be around 40-60
Posted on Apr 04, 2011
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
Bought a house with Lennox G12Q3-82-3 furnace. It doesn't look like electronic ignition. A sticker showing AirMedic Electrostatic Air Cleaner says it was installed 10/1992. Doesn't work.
Here's some borrowed info.:
`These are classic symptom of a limit switch opening. Can't guarantee that is what is going on, but here is some things that can cause the limit switch to open:
1) Low air flow. This can be caused by dirty filter, dirty blower wheel, dirty air conditioning evaporator coil, restricted or collapsed ductwork, blower motor running the wrong direction, blower running on too low of a speed, defective limit switch, or a combination of several of these factors. Inspection along with measuring the temperature rise will find most of them.
2) Heat exchanger failure. Split or burned through heat exchanger
3) Over-fired furnace. If you have eliminated everything in section 1 and 2, and the temperature rise through the furnace is still high, you need to check the furnace to make sure it is not burning more fuel than it is designed to burn. If it is a natural gas furnace, you can check the amount of fuel that is being burned by clocking your gas meter.
Here is a link that will tell you how to use your gas meter to calculate the BTU input of your furnace. It should never be more BTU than the furnace's rated input.
http://www.bacharach-training.com/referpage/clocking_gas_meter.htm
The problems you have could be potentially hazardous. If you are not able to aggressively find the problem on your own, you should hire a professional to look at the furnace immediately. The G12 furnace is getting relatively old. If you have never had it professionally inspected (sounds like you haven't), you probably should have a professional look at it immediately.' END QUOTE
This might cover your problem? don-ohio (:^)
Dec 19, 2016 | Heating & Cooling
Why is my heating system short cycling?
What is your Temperature Rise across the furnace? Match this with the name plate. This tells you a lot. Is the t-rise higher or lower? If its higher, you could have restricted airflow or exhaust issues. If its lower, could be gas pressure or duct work problems, pulling in colder air somewhere. More info is needed to help. I am assuming the furnace is operating continuously when you say it will not heat over 66 degrees?
Feb 16, 2015 | Heating & Cooling
Furnace lights blows heat in cycle, pops sensor on blower and continuosly blows air until button on sensor is pushed back in
You are over heating because of dirty filter, coils, or bad or collapsed ductwork check return especially. on the units data label there should be a max and min temp rise this is the difference from incoming and outgoing air through the furnace. Check this.
or it could actually be a bad switch.
Oct 25, 2012 | Intertherm 56000 Btu Gas Furnace
Gas Furnace Model GMH 95070, installed May 09. Air flow from registers noisy. Installer reduced it one level -still noisy. Said it cound not be cut lower because it would get to hot due to slow air flow. I...
Seems to me, the problem is not with gas, it's with the size of the duct work. 4" diameter is way to small if the entire duct work system is only 4". The trunk line may have not been sized proper,y. so the volume of heat has now been translated into high pressure, which is why the registers are noisy.
Also 6" ducts coming off a larger trunk line to each register is the norm for 1000 sq ft home.
Also, are your registers in the floor or the ceiling? Ceiling registers historically are a little noisier than floor registers. Mainly because, they're overhead and closer to your ears. But, if they were up-sized to 6", the noise would decrease quite a bit.
Hope this helps.
Feb 10, 2011 | Goodman Heating & Cooling
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Gas Furnace doesn't come back on after giving heat for a while.
This is an erratic operation of the thermostat you can reset the thermostat. Please check the reset operation procedure of the installation manual
Nov 18, 2008 | Tappan 30IN ELEC IGNa Oven
I have a gmpn-80 janitrol 90% eff gas furnace,it is only 15 months old,my condisation tray is melting and cracked do to heat in which case leaks water all over....why would this be happening?
Most likely the cause is that the furnace is firing too hot. When a furnace is installed and set up, the manifold gas pressure and fan speed has to be set by the technician so that the temperature rise through the furnace is a maximum of 50 deg F (i.e. if air enters the furnace at 68 deg F it come out no hotter than 118). The target temperature rise on any gas furnace is anywhere between 30 and 50 deg F. If the furnace runs too hot, either the manifold gas pressure must be turned down or the fan speed must be turned up to keep in this range.
Jun 28, 2008 | Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
