Question about Electrolux Refrigerators
COMPRESSOR STARTS BUT STOPS IMMEDIATELY NO COOLING
    Sergeant:
    Champion:
  • 202 Answers
Hi.... I would start with getting a start relay and start capacitor ....if it still won't start and run you have a bad compressor
Posted on Apr 03, 2011
3 Suggested Answers
  • 358 Answers
SOURCE: MOD FRS6B7EESB5 - Stopped cooling, fan is working,
Replace the relay (no more than $20) and if still won't start the compresor has to be replaced.
Posted on Aug 19, 2009
heatman101
  • 43501 Answers
SOURCE: Loud click,compressor starts, immediately stops.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
OUTDOOR UNIT START AND IMMEDIATELY STOP
Its probably a safety causing it to cycle off, or a component failure. It may have a low pressure safety switch. In the event of freon loss, this safety does not allow operation to prevent compressor damage. Or it has a high pressure switch. Same process but prevents excessive freon pressure.
Mar 07, 2017 | Heating & Cooling
Electrolux split A.C. display F6 error and trips immediately after starting the compressor.
Anti high temperature protection.
Check the outdoor coil for airflow obstructions.
Check the outdoor fan motor for correct operation.
May 23, 2016 | Electrolux Heating & Cooling
Why is my Dometic Brisk Air air conditioner not working?
Sounds like the compressor is seized up and the smell is from the clutch slipping when it tries to engage. If that is the case, you need a new compressor at a minimum.
Aug 04, 2014 | Dometic 457915 Duo Therm Brisk Air...
CONTACTOR RELAYCLOSE BUT LOOK BURNED , FAN MOTOR START , BUT COMPRESSOR MOTOR START AND STOP IMMEDIATELY. CONTACTOR STAY CLOSE BUT COMPRESSOR DON'T RUN.OR COME ON AND STOP IMMEDIATELY.
sounds like a locked rotor, did the compressor get hot? did you check max amps on the compressor when it attempted to start?compressors have thermal protection built into their windings, a switch that will open to protect the compressor, and if the rotor is locked, normally you have to replace it, you could try putting what is called a start assist capacitor on it (AKA hard start kit) I would recommend the two wire model, easy to install.
You will need to wait for the thermal overload to reset, turn power off to unit till you get the kit on there.
Jul 18, 2011 | Heating & Cooling
Loud click,compressor starts, immediately stops. Then a click ,fridge light dims for a couple of seconds. compressor starts and continues to run. Fridge cooling ok.
heatman101
Aug 30, 2010 | Frigidaire FRT17G4B Top Freezer...
My Amana 20 refrigerator does not cool. It starts
yes, it can be repaired but ir can be expensive.Compressor problem, filter problem, check with a certified technician
Aug 28, 2009 | Refrigerators
My (very old) Beverage-Air MT45 refrigerator just stopped cooling. The compressor seems to switch on, then immediately turn off. Is the compressor bad or just the start circuit? Anyone know how to...
turn it off let it cool go to parts house get a pro41 relay if that don't work the compressors frozen is it less than 5 years old it may be under warranty
Aug 02, 2009 | Refrigerators
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
153 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
