Question about HP Color LaserJet 2600n Printer
HP color laserjet 2605dn: I have blue stripes on my paper: on the left side 1cm and on the right side ca. 2 cm If I print a page in colour, then the stripes are in strong blue, if I print a black/white paper then the stripes are in light blue what has to be repaired?
  • HP Master
  • 1,915 Answers
You likey have a bad CYAN cartridge, that is the first thing you want to replace.
Posted on Apr 03, 2011
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
I have just replaced my cartridges and the printer is now printing with a four blue horizontal stripes across each A4 page (each about 1cm wide). Please can you help.
sounds to me like the cyan toner cartridge is defective, if you still have the old one, put it back in and see if the lines disappear. Get Paid
Jul 28, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
When I print a color page, there is a multi colored line about a 1/2 inch thick along the left side of the paper. The print quality is good for everything on the page, just this line of swirled colors. ...
Run the Print Quality test. Sounds like one of the color cartridges is bad.
Also run the Disable Cartridge test. That will let you test each cartridge by itself.
Before you do that, open the front door halfway. Now you can see each of the color drums in each cartridge. One of them may have a 1/2" stripe on the drum on the left side.
Nov 29, 2010 | HP Color LaserJet 3500 Printer
The right side of the page does not print - HP 2605DN
Most likely the cartridges are out of toner. Or something is obscuring the path of the laser writer. If changing the cartridges does not solve the problem the machine will need servicing. Service manuals are available but not as comprehensive as necessary to fix this problem. Below is a very good DIY guide, but be very careful if you choose to do this yourself and follow his directions precisely.
http://www.reeves-hall.net/tech-gadgets/fixing-washed-out-colour-on-hp-color-laserjet-2605/
Jun 08, 2010 | HP LaserJet 2605dn Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
Colors are uneven, too much green on the right side and too much red on the left
The internal optics are dirty. It's a known problem that HP's been ignoring.  More info is here:  http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1202453734788+28353475&threadId=1073731
Detailed instructions are on this page - look for Don Thompson's posting at Sep 15, 2007 23:38:51 GMT and click the papercliip to see the procedure. It's not for the faint of heart.
Dec 12, 2007 | HP Color LaserJet 2600n Printer
HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Oct 07, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
1,486 people viewed this question
Seeker5211
Seeker5211
