Question about Philips Audio Players & Recorders
Everytime i try to play my system at full volume it cuts out then keeps playing and carries on doing this to i turn it to a certain volume
  • 635 Answers
First of all find out the recommended speaker impedance for the receiver. Then find out the impedance of the speakers you are using along with it.
Simple rule is the speaker impedance can be higher but not lower than the recommended value. If it is so the receiver will run hot and if you turn up the volume higher it will run even hotter and then the protection circuit will cut off the Amplifier output to prevent burn out of components. Even if you have one defective speaker this cut off can happen. To confirm defective speaker -- disconnect one speaker at a time and turn on the amplifier and play it at cut off volumes.If by disconnecting one particular speaker the Amplifier does not cut off -- THAT SPEAKER HAS A SHORTED COIL and needs replacement.
Posted on Apr 03, 2011
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
Head set is cutting out
Sounds like the system is being overdriven. Have you tried lowering the volume control?
Sep 17, 2014 | Shure PSM200 Wireless In Ear System...
Hey I've had my Logitech z506 speakers for a few
I don't know for certain but, this is usually a sign of the overload circuit in operation. Speakers are not designed to be used on full volume constantly. Next time this happens try and turn them off for a couple of minutes, when you turn them on again try with the volume lower than when you turned them off. If you are regularly using them at full volume, then maybe it is time to invest in a more powerful set. Buy them by their RMS power output, NOT by their PMPO (peak mean power output) this is already an inflated figure and is usually about 4 times the real power output. I hope this helps.
Jan 21, 2013 | Audio Players & Recorders
Static when playing music and speakers pop
try to clean the volume control with contact cleaners
May 05, 2010 | RCA RT2760 System
KEEPS CUTTING OUT
put a cd cleaner in it and play it a few times should do the trick even if it won't play but for three sec.
Jan 10, 2009 | Car Audio & Video
Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 22, 2008 | Harman Kardon Go + Play Portable Speaker...
PS3 Refuses To Play Certain Games
do we really need the Sony PS3 2.43 update to fix the current 2.42?
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
Won't play My music i downloaded
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 25, 2008 | iRiver H10 MP3 Player
System keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Nov 17, 2006 | JVC MX-K30 CD Shelf System
185 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
