Question about Oreck Professional Air Purifier Air Purifier
How do i open to clean the filter - Oreck Professional Air Purifier Air Purifier
    Brigadier General:
  • 4,736 Answers
Is you have misplaced your Owners Manual you can go to http://www.oreck.com/Owners-Guides#
find your model and download and print the Owners Manual/Guide. Tis way, you'll have it for future reference.
Posted on Apr 03, 2011
25hp kohler hot start problem. Replaced fuel filter, plugs and cleaned air filter - same problem. it won'd restart when hot.
3 possibles come to mind
fuel vaporization in the line to the carby or in the carby bowl (check float level adjustment)
valves are being held open when hot--- valve stem lengths increase reducing tappet clearance___adjust valves when hot
check coil/ ignition module for failure when hot as they can open circuit ./ short circuit when internal components fail from heat
Sep 27, 2016 | Kohler Command V-Twin Horizontal Engine...
Why doesn't the fan engage? The filters are perfectly clean and it receives power
See if the motor is bound up. Move the fan blade to check for stiffness. The motor may just need a drop of oil. There is an internal fuse in the motor that you cannot change It may have opened. If you have access to a volt meter check all the wires on the power switch
Jul 16, 2014 | Honeywell 50150-N True HEPA Allergen...
Resetting Filter status after cleaning filter
MAKE SURE THAT THE LID OF THE FILTER IS PROPERLY CONNECTED SOMETIMES THESE DEVICES ARE
BUILT WITH SWITCH FILTER
Jan 13, 2014 | Honeywell Air Purifiers
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
I have cleaned the filters, and i still get the Clean Filter message. It is running fine, but the red letters Clean Filter are still there... any suggestions???
How did you clean the filters? I run mine through the dishwasher by themselves and it works pretty good. The tops and bottoms of the filters near the edges need to be wiped pretty clean.
Jan 02, 2011 | Brookstone Pure-Ion (506840) Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
IONICPRO TURBO
I had the same problem and was about to open the unit up to see if I could adjust the sensitivity of the "clean light" trigger. Yeah yeah I know.. high voltage and all... but I'm an electrical engineer (which means I would know exactly what killed my dumb-a$$ after the fact). While looking I discovered a separate set of contacts under the swivel door. That is to say, unplug the unit, open the door, and remove the metal filter part (the thing you clean) according to the instructions. Look just below the lower part of the door (in between the door and the case) and you'll see a metal post and another metal tab. When the door closes, the two make contact which completes the circuit. In my case, they were covered with dust. I took some long Q-tips and cleaned them off and the unit started working properly again. There may be other things to clean along the circuit, but I believe that this is a step that should be done each time you clean the filter. Good luck.
May 18, 2008 | Ionic Pro TURBO Air Purifier
Wont run after I cleaned it
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Feb 09, 2008 | Hunter 30200 \ 30010 (Set) Air Purifier
Cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Oreck Professional Air Purifier Air Purifier Logo
244 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
