Question about Integra DTR-5.2 Receiver
The amplifier will cut off after 20 minutes or less of use. Restart it and it will run for 10 to 15 minutes and spontaneously cut off again. Unit does not seem to be overheated but is very warm to the touch.
  • Integra Master
  • 6,694 Answers
First of all you have to check the speakers impedance. It should be 8 Ohms.
if the Ohms of the speaker is lower than 8 Ohms, it will overload the amplifier and will over heated and will switch off to prevent further damages. try to use speakers which have impedance of 8 ohms.
ok
Posted on Apr 03, 2011
My husgvarna staggers after a while of cutting then dies whats the problem
i am going to guess that it won't restart immediately after it dies either. It sounds to me like an ignition module going bad. it gets hot then cuts off the spark, once it cools down it starts and runs again until it gets hot again
Feb 27, 2013 | Garden
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Amplifier cuts of after 20 min playing
Sounds like a component inside is overheating. Might suggest taking to a car adio specialist to fix but could be expensive to repair. A new replacement maybe cheaper.
Sep 02, 2012 | Car Audio & Video
Unit stops rinning after 15 minutes ande a sign appears in the window saying c6. turn off unit at main switch and wait for 15 minutes and unit starts adain for a further 10 to 15 minutes and cuts off...
Compressor run current high. Check condenser coil dust blocked. Clean it. Check fan motor- if less rpm, replace capacitor.
Best solution:Do water Service and then check. If still amps gradually increase, replace capacitor.
Thanks and hope helpful.
Jan 28, 2011 | LG Heating & Cooling
Motor starts and runs for less than a minute then cuts off and WILL NOT CRANK OVER again for 15 to 20 minutes. then it cranks over, starts, runs less than a minute and cuts off again. it has been fine...
It sound more like a plugged catalytic converter. When you start the engine the pressure starts to build until the engine sufficates then after you let it set the pressure bleeds off and lets the engine restart.
Jun 23, 2010 | 1989 Chevrolet Suburban
Mower runs for only 15 to 20 seconds then cuts out will restart first pull after acouple of minutes then cuts out again etc.
check fuel flow to engine. check spark plug. check oil. check air flow to engine.
replace air filter.
Aug 06, 2009 | Garden
Sputtering, chugging, black smoke - won't restart when hot
check your tail pipe for a "clog" engine not breathing correctly.
Jun 22, 2008 | 1993 GMC Sierra K1500
Vapor lock?
keep the fuel tank at least half full.....it may helps cool the pump
Jun 19, 2008 | 1991 Volvo 240
Front speaker channel cut off
I lean toward an overhating condition since the unit does not go into protection mode right away, and then returns.
My thoughts are as follows...
1) The receiver needs better ventilation
2) The speakers are below the rated minimum nominal impedance, causing the amplifier to strain and overheat
3) There is a problem within the amplifier that is causing this problem - this is not user repairable.
I'd try another pair of speakers which are rated at 8 ohm nominal impedance and give it a trial. At the same time, monitor the heat output from the unit (note that modern amplifier sections do run hot). If the unit runs extremely hot at a low volume and still shuts down on 8 ohm speakers, it's time for service or replacement depending on value.
Oct 30, 2006 | Sony STR-DB940 Receiver
Integra DTR-5.2 Receiver Logo
175 people viewed this question
Top Integra Audio Players & Recorders Experts
Electro Med Services...
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
