Question about Panasonic Lumix DMC-ZS3 Digital Camera
Lens will not retract back into the camera. Cannot make photos now
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 03, 2011
My camera is Kodak and its model is M883, actually while taking photos the camera is slipped from my hand and the lens of its was strucked.So i cant take photos due to no lens movement. So plz give a...
If it appears undamaged, you could remove the batteries and see if that causes the lens to retract back into the camera, to get it unstuck, just as it retracts when you turn the camera off. Good Luck to you.
Dec 16, 2010 | Cameras
My SAMSUNG TL100 CAMERA LENS STUCK OUT SIDE
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Mar 04, 2010 | Samsung TL100 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
The lens will not retract. A message says "lens error, restart camera," but the camera will not restart. The camera is a Canon PowerShot S3 IS. I can hear a "whirring" or motor noise when I try to start...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some simple things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 17, 2010 | Canon PowerShot S2 IS Digital Camera
Sony Cyber Shot lens extends and retracts, can't take photo
My solution for the M340
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Sep 13, 2009 | Kodak EASYSHARE M340 Digital Camera
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Casio Ex-z55 Lens cover not closing and lens does not operate
Buy the next camera- at 3 years old no economic repair will be feasible- but you could play with it some I guess
Aug 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Panasonic Lumix DMC-ZS3 Digital Camera Logo
296 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
