Question about Cameras
I have the Roland vr700 and would like to know how to change the split sounds
    Scholar:
  • 35 Answers
Here's the link to 2 user manuals for Roland VR700.
First one is specifically for Splits and Layers feature while the secind one is the general user manual for the same.
http://www.roland.co.uk/assets/media/pdf/VR700WS02.pdf
http://www.roland.co.uk/assets/media/pdf/VR700WS01.pdf
Hope it helps!
Both links are for PDF files so please ensure you have Adobe Reader to read these files.
Thanks.
Posted on Apr 03, 2011
Can drums of G600 keyboard play in roland e500
As far as I know, Roland programs all it's drum sounds in all of it's instruments from the factory to the same note numbers.
Jan 12, 2016 | Roland Music
Roland EP50 F sharp does'nt work.All other keys are fine
EP-50's are notorious for problems with either the 4.65 voltage feed to the velocity sensitive keys or failure of the small zenner diaodes. Each key has a pair fo split circles on the circuit board under it. When you hit the key you connect each side of the circles and the harder you hit the keys the quicker the circuits close the louder the sound. Problem is if the voltage to either circle fails, due to bad solder, scratch on circuit board, failed diaode then the sound disappears. The fix is simple if you are knowledgeable on solder on circuit boards, can use a multimeter and can dissassemble and reassemble the keyboard. If you have to take it to a repair shop it is probably not worth fixing as this is not one of the better Roland products
Dec 03, 2012 | Roland Music
Mitsubishi M-VR700 no sound
Check your remote it may be in a different mode or your wires or cables maybe disconnected
Feb 21, 2012 | Mitsubishi M-VR700
I have a mitsubishi m vr-700 receiver and I had someone hook up the five speakers up to it last night. It was working fine. This morning I turned it on and no sound. how do I fix this?
I bought a Mitsubishi M-VR700, which produced no audio from the speakers, but with headphones, a tiny bit of audio was detectable with the volume control on max. This solution was posted on FixYa by Mojorisin65 some time ago: Facing the receiver directly behind the MITS logo & power button is a vertical board with a large IC on it, try flexing the board near the IC while turning the reciever on & off or changing input modes, there is a cold solder joint on this board which I haven't found yet. I understand this is a common problem with the MITS M-VR700-900, Onkyo TXDS-575, & Integra DTR5 or DTR5.1 ( all made by Onkyo).
I gently flexed the board as described, and Boom, all the audio was back as it should be. I suspect Mojorisin65 is correct about the cold solder joints, but with SMT components, it could be very difficult to find. I may very well be on one or more of the 48 pins on the large IC. This IC gets rather warm during operation, which may explain why some units may work until it heats up. The chip gets warm and 'twists' enough to lift the bad pin(s) from the circuit board. In an attempt to deal with this symptom, I superglued a TO-220 heat sink to the top of the IC (don't let it touch the case of C-716). The heat sink is dissipating a fair bit of heat, and so far, this 'fix' seems to be doing the trick. RJD 10.18.11
Jul 08, 2011 | Mitsubishi M-VR700
Roland fantom g8, problem, The last 2 octaves do not issue sound
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
Feb 23, 2011 | Roland FANTOMG8
I don't no how to record in split layer. And do I twerk this keyboard
I don't know what you are using to record with but if you are recording audio try sending half of the split right and the other half left or use two separate channels to record each half. Mix as needed. If you are recording midi using a DAW assign each half of the split to a separate midi channel and assign the receives to separate channels in your DAW. If you are recording onboard your manual should have the solution and you might just have missed it so far.
Oct 25, 2010 | Roland FANTOMG8
I was looking at a 2nd hand KR 103 to buy. If while playing notes the damper pedal is pressed all sound is muted. Is there a function switch or something that needs swiching on to get it to work? The...
Please note that ROLAND equipment USUALLY uses Normally closed (electrically) damper pedals for their equipment. Most other brands use normally open ones. If you are using a non-Roland pedal, that is likely the problem.
SOME PEDALS require opening and changing a wire (involves soldering) to match the unit you are plugging into. A very few have a switch on them to allow changing polarity.
A few synths, like the Yamaha Tyros have a built in setup screen where one can select the polarity of the attached pedals.
Sep 23, 2010 | Roland Dp 2 Damper Pedal
We have the roland juno d and we can't figure out the split for two sounds
you could try using 2 midi channels for two sounds.
Feb 11, 2010 | Roland Juno-D
A split on a roland Juno-D Key-board 61 key
Pick Patch Mode
Pick patch e.g. Moog Lead
On the Eidt Section of buttons: Parameters (click once)
This should show on the orange screen
PATCH l COMMON
NAME : MG Lead 1
then navagate using the right left buttons to
PATCH l COMMON
KEY MODE: SINGLE
Then press the split button (this is located on the right hand side of the board beside the ADSR pramaters) cick this until the light signifies that the board has been split aka the light beside the button is beside the word split
then navigate on the Orange screen to this
PATCHTONE (both)
NO.------MOOG
While on this screen press the upper/lower button on the right side of the synth.
this will then change the PATCHTONE (both) to PATCHTONE (upper) or PATCHTONE (lower) depending on what part you pick
then scroll through the tones you want for each part of the keyboard e.g. Tuba Left abd Trumpet right
Now what needs to be done is pick where the keys split e.g. C2 C3 C4 C5 or andy key on the keyboard not just the C's
PATCH l COMMON
Split point : C4
and then choose your split point
Now that youve finished you can save this setting for later playing. Navigate to:
PATCH COMMON
Write
pick your place on the keyboards memory I suggest one thats not already taken these are normally identified by this e.g. U00054
then click enter twice and you have yourself a nicely split keyboard! Enjoy!!!
Nov 20, 2007 | Computers & Internet
Receiver
I have the same problem.
Is there a solutions besides replacing it?
May 22, 2007 | Mitsubishi M-VR700
Cameras Logo
82 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
