The water does not drain and so it do not spin
    Brigadier General:
  • 3,917 Answers
Hi
There are various reasons as to why a washer wont drain and spin. Please check the bellow link to have a detailed idea related to your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itwontdrain
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 03, 2011
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Elba washer is not washing or spinning right...the only thing its doing is adding water
I couldn't tell if the water was draining. When you advance the cycle to spin the first thing it should do is drain the water. This will happen for a short time before it spins. If it is not draining then you need to check the drain pump for blockages( and pipes) the machine will not spin with water in it! If it is draining but not spinning then it is probably a faulty lid switch and needs replacing. There are a couple of other causes but they will usually create a fault code which you don't seem to have. Most likely blocked or faulty drain pump.
Jul 05, 2013 | Washing Machines
My machine is barely draining water on the drain and spin cycle. It will spin but does not empty all the water out of the machine.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up...
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Apr 07, 2011 | Kenmore Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
