Question about Dacor Preference RSD30 Gas Kitchen Range
I need to replace the door hinges on my Dacor RSD30 range. How do I remove the front plate of the oven and replace the hinges (I have the new parts.)
SOURCE: Dacor oven will no heat.
This solution worked for me. My gas oven would not work even though my burners would. There were 6 screws to undo and I removed the screen that led to the thermostat. Note: the reset button is located on the top of the thermostat and is red (actually is a square red button) - it is behind another round metal disk (that you first will see after removing the metal screen) with wires plugged into to but if you look from the front side view you will see it behind the disk. I reached back with my finger and pressed it down to reset. Thanks all for this great tip - saved me a service call!
Posted on Dec 24, 2007
  • 131 Answers
SOURCE: Replace RSD30 oven control
This is one of the hardest stoves to get into. Turn off the breaker.
Pull off the burner knobs. This should reveal four large plastic nuts holding the console in place. You can turn them gently with channel locks straight on - not from the side. After you've got the console loose, everything else is downhill. There's lots of screws behind console, and across the bottom of the console (just above the door.) Remove just the ones you need, or face the wrath of Dacor!
Be careful about the rubber strip across the top of the console. It often stretches during a repair. You might have to cut off 1/4 to 1/2 in to get it to fit again.
The large plastic nuts are very east to get cross threaded when replacing them. I recommend turning them counterclockwise until you can feel the threads line up.
Posted on Mar 11, 2008
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
vanni7
  • 163 Answers
SOURCE: Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Posted on May 05, 2009
The oven shut off half way through baking on convection, the fan still works, the clock still on, other functions seem to work but now the oven will not come up to temperature what can cause this?
The door closure latch can cause such an issue, if is isn't engaging correctly. Otherwise your RSD30 may need to be reset. Follow the instructions in the owners manual to reset. If you don't have a copy, the link attached below is free to use. Dacor rsd30 User Manual
Mar 12, 2015 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Describe your dacor rsd30 new oven door Problem - the glass is broken in the window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Nov 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
I have a Dacor ERD36, How do I remove and replace the oven door hinges?
most ovens , you open the door half way, then pull straight up the door will come right off, then you have full view of hinges and bolts
Oct 19, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
Oven does'nt stay on.
SOUNDS LIKE TERMOSTAT REPLACE THIS AND OVEN SHOULD WORK.
Oct 13, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor oven door will not lock to do self cleaning
Hi!!! You have a problem with your door lock mechanism.it wont lock because its bad..Replace it and you should be fine.Good luck..
Jan 04, 2009 | Dacor Preference RSD30 Gas Kitchen Range
RSD30 F1 Error Code
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection. why would he replace the spark module?if the door is not closing>>> are the burners not igniting?
Bezel Panel
76480b/r BEZEL (Almond/Black/Arctic)
Spark Module
86526 SPARK MODULE, 4 POINT,
Both door hinges
82883 HINGE, DOOR
* 82508 HINGE, DOOR (Stainless Front)
or to fix your F1 error
92028 RELAY PCB, 105 C
Aug 01, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Mar 11, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
171 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
