Question about Cameras
Flash symbol is flashing on screen as well as E901:01. Camera hasnt been used foe several months
Arpi
  • 326 Answers
SOURCE: Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Posted on Mar 27, 2007
avaya pimp
  • 23 Answers
SOURCE: E:91:01 flashing and beeping few secounds after camera is turned on
e:91:01 is a flash error you might fix it by initializing the settings of the camera but there is no guaranty.
1.turn the unit on
2.press the menu button
3. select setup
4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
6.if succesfull(you'll get clock settings)
7.set the date and time then try the camera again.
if this does not work.... call sony cust service 1800-222-7669
Posted on Jan 30, 2008
SOURCE: E:91:01 problem on sony dsc-w100
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Posted on Sep 03, 2008
  • 74 Answers
SOURCE: My camera flashes E:91:01 and
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Posted on Sep 12, 2008
taran_2005
  • 10515 Answers
SOURCE: my flash does not work and screen flashes E:91:01
Already solved by an expert :-
Please initialize your cyber-shot and this option is available in camera Menu. Hope this would solve problem.
Thanks.
Posted on Jun 28, 2009
Installed new film memory stick and new charged battery.......... screen flashes format error with several flashing symbols....help.
Hi, best bet, try formatting the memory stick first, then use with camera, format will create a FAT system, should work.
Mar 02, 2015 | Cameras
I have a canon powershot 130 that is only 6 months old, the flash is not working. Ive raised it and lowered it and it still says the flash isnt on?
To turn the flash ON please follow the instructions below
  • Raise the Flash
  • After pressing the 'right arrow' button turn the mode dial button (round button) on top to choose 'zigzag down arrow' symbol on the screen.
  • Then press the FUNC.SET tinualbinale_17.jpg button.
  • Once set, 'zigzag down arrow 'symbol will appear on the screen. Now the flash is turned on.
  • Your valuable feedback would be appreciated.Please post me a reply if you need further assistance.Thanks.
Jun 11, 2011 | Canon PowerShot SX130 IS Digital Camera
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
Need to suppress flash
The flash mode button is located to the right of the zoom button. Press the button several times to cycle thru flash modes.
Suppressed flash is the round symbol, where the lightning symbol is crossed over.
Jan 14, 2010 | Fuji FinePix A340 Digital Camera
Turn off flash
With the camera ready to shoot in Auto mode - you will see a little lightening symbol in the top right hand corner of the screen. This indicates the flash is turned on.
On the left side of the circular dial at the back of the camera you will see a similar little lightening symbol indented into the dial. Simply press on this side of the dial to turn the flash on or off as you desire.
The symbol on the screen will go off when you push this to indicate flash is off and return if you press again to turn it on.
Thanks for using FixYa.
Dec 30, 2009 | General Electric A950 Digital Camera
My flash has stopped working
Hi
Unfortunately you will either need to replace the flash unit... or if you're unlucky the main PCB. I don't think you will be able to do anything without either of those parts.
I have made my living running a digital camera repair business for several years now, wish I had better news for you about your camera. If we can help with the repair let us know.
Good luck: Darntoothysam com
Thomas
Sep 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
G9 flash
In your display, is the small lightning symbol appear on the screen? Try cycling through the various flash options by pressing the "flash" lightning symbol to the right of the monitor. If the flash is set to flash when there's not enough light at the G9's descretion (with an "A" next to the symbol) then the flash may or may not go off. I oftentimes set the flash to go off all the time if the camera is not doing it automatically (with the A next to the symbol). Being in Auto mode versus the other preset exposure modes affect the flash options available too.
May 20, 2008 | Canon PowerShot G9 Digital Camera
Flash not working...
I have a DSC-W80 CyberShot I had a problem with the error code on the LCD Screen that said E:91:01. I played with the camera for a little bit and found the if you push the home button and go to settings. When you get to the settings go to main settings, When you get there go to initalize and follow the instructions. MAKE SURE YOU SAVE YOUR PICTURES OR TAKE THE MEMORY CARD OUT OR YOU WILL LOSE ALL THE PICTURES. I hope this will help you.
Jan 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
How do you turn the flash off?
christinaaa: You must pressed several times the FLASH button until the regular FLASH ICON (The Thunder Symbol) appears inside a circle. This mode is called "SUPRESSED FLASH"... SithPitt
Jul 04, 2007 | Fuji FinePix A340 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
