Question about Frigidaire FEF366 Electric Kitchen Range
Oven door I took the oven door off my kenmore stove and i can,t get it back on
  • 943 Answers
Hi thanks for the question. lay the door on the floor .the hinge must be locked before it can be installed back in the oven. each hinge has a locking clip . push down on the hinge and lock with clip . same on the other side. install door. push door down. unlock the clips. close door. to remove door. push door down. lock clips . pull oven door out . thanks the appliance doc
Posted on Oct 06, 2008
  • Ellen Piper
    Ellen Piper Mar 19, 2014
    how do I push down on the hinge? It snaps back immediately.
Oven door
Nectar time take a photo first, they generally only go back one way.
removing the door may make it easier open the door see the hinges on the bottom lift up the little cam on each hinge then just lift the door up & it should come out.
Apr 17, 2014 | Kenmore Sears Electric Range Stove Oven...
C970 555821 Kenmore oven
Look for the model number inside the oven door area. The number you posted is incorrect.
Dec 22, 2013 | Kenmore Kitchen Ranges
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Aug 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore ceramic top electric stove door problem
For a while, they were building Kenmore stoves with hinges that get bent out of shape easily. If your stove is still in warranty, (I'm sorry to say) call the 800 number for a repair. You can get a Saturday appointment if you're persistent enough.
If not in warranty, the hinge kit should still fix it, and the parts are about $45.00 for both, and they come with instructions. It took me about an hour the first time, but I've got it down to 25 mins. You'll need a square drive bit, and beware of the very sharp metal edges.
If you have a warming drawer in the bottom, it's more difficult. In this case, removing the drawer is harder. And after getting the drawer out, the metal liner along the sides of the drawer have to be loosened in the front and bent inward out of the way. Don't worry, they go right back with no trouble.
If you decide to pay someone to do the work, please call a local company.
Mar 31, 2008 | Maytag CWG3100A Gas Single Oven
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Frigidaire FEF366 Electric Kitchen Range Logo
579 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
