While typing M ,0 comes, - Computers & Internet
  • 3 Answers
Your num lock key is probably on. press the Function key, (Fn) and find a key with [num lk] on it. Usually it is the scroll key. Or alternatively, you can just restart your PC.
Posted on Apr 03, 2011
How do I type the number 0? It comes out as /
Has anyone worked on your laptop, I suggest you goto Notepad and press every key on the keypad until the 0 comes up Maybe your key buttons are off or someone put them on wrong when they fell off.
Feb 02, 2015 | Computers & Internet
Tip
How to set the Clock Rate in the serial interface on a Cisco Router
From the UserEXE mode type enable command to get the Privilege mode
Router1> enable
Router1#
from here type configure terminal to get into the Global configuration mode
Router1# configure terminal
Router1(config)#
from the global configuration mode go to the serial interface where you want to set the clock-rate type the command interface serial <serial interface number>
Router1(config)# interface serial 0/0/0
Router1(config-if)#
from here type clock rate <rate> command
Router1(config-if)# clock rate 64000
But clock rates are only set if the serial interface is DCE. To check that the interface is DCE type show controllers serial <serial interface number> in the Privilege mode that is Router#
Router1# show controllers serial 0/0/0
Enjoy networking.
on Jul 03, 2010 | Computers & Internet
Toshiba studio 181 error c44
This error indicates that the print count has gone above the limit and it requires service. But, this is not necessarily true. Try the following to reset the count:
Solution:
  1. Switch off the printer first.
  2. Now Power the Printer by pressing 0 and 8 keys (keep pressing).
  3. Then a test mode comes up.
  4. Now Type 400.
  5. Press START (!)(You will get a counter and now you need to reset this).
  6. Type 0.
  7. Press Enter(start)
  8. Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
  9. Now switch off the printer and on it normally.
  10. You should see printer working normally
Resource: Clear Toshiba eStudio printer error message Error C44 call service
Jul 23, 2014 | Toshiba Computers & Internet
C44
  4. Now Type 400.
  6. Type 0.
Jun 05, 2011 | Toshiba Office Equipment & Supplies
Cod c44 for copier toshiba
  4. Now Type 400.
  6. Type 0.
Jun 04, 2011 | Toshiba e-Studio 205 Copier
I need to fix now this cod c44 i know that is fusing problem but ao can i reboot the machine or reset this cod for copier toshiba studio e 205
v Switch off the printer first.
v Now Power the Printer by pressing 0 and 8 keys (keep pressing).
v Then a test mode comes up.
v Now Type 400.
v Press START (!)(You will get a counter and now you need to reset this).
v Type 0.
v Press Enter(start)
v Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
v Now switch off the printer and on it normally.
v You should see printer working normally
Lexmark model which I have purchased is not on my computer drivers Model X5495
The printer should have come with a CD. Here is a link to Lexmark. Choose to Download Drivers and then type in your model number X5495.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Nov 19, 2008 | Computers & Internet
I need solve this type calulation is 0,1,1,2,3,5,8,13,21,34 etc. u send me the code of this type of calculation in c++ language
Ok! Here's a snippit from some code I wrote in beginning c++ classes. However, don't just cut and paste it. Know how it works since it's important in algorithm examination!
Just tested it, compiles and runs perfectly on GCC 4.0.1 on my mac, as well as my linux boxen. Windows may take some changes to output data.
* Steven Parker
* Calculating Fib Sequence
* after two starting values, each number is the
* sum of the two preceding numbers
#include <iostream>
using namespace std;
int main() {
int whentostop = 20; //How many values of sequence to calculate
int fib[whentostop]; //Hold fib numbers
for (int i=0; i < whentostop; i++) {
if (i == 0)
fib[0] = 0;
else if (i == 1)
fib[1] = 1;
else
fib[i] = fib[i-1] + fib[i-2];
cout << "Fibonacci[" << i << "]: " << fib[i] << endl;
return 0;
Nov 12, 2008 | Computers & Internet
LG HT353SD?
open tray
0 0 0
then appears a screen asking for region, put 0 for free region, then press pause.
done
Aug 23, 2008 | Philips MCD288/37 DVD Micro Theater System...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
