Question about Dremel Variable - Speed Multipro Rotary Tool 395
Putting new brushes on a Dremel model 370-5
At high speeds the motor no longer sounds smooth. I have not changed the brushes since I bought the tool many years ago. What else must I do to service this tool?
  • David Ford
    David Ford May 11, 2010
    By sounds smooth do you mean vibration or not running up to speed. It could be the bearings are drying up putting a strain on the motor. Yes the brushes can be changed but I don't know if that would cure your problem. Unplug tool and turn shaft by hand to see if it is smooth. If not look at the bearings and also the coupling.
SOURCE: Is there a reset button for a Dremel Multi Pro?
When the brushes go on my Dremel, it just stops, sometimes erratically - no smell or burning.
Posted on May 23, 2008
  • 7 Answers
SOURCE: How to replace brushes?
On either side of the switch is a black disk with a notch small enough for a small screwdriver. Unscrew it and take it off to expose the spring. Gently pull the spring out and the brush should be attached. If you encounter resistance, then you may disconnect the spring from the brush. If this happens then push the spring back in and hope you catch the brush; if this does not work, then get creative or take the whole thing apart to get to it. After that, just put the new brushes in and recap.
Posted on Aug 03, 2008
mikedem7
  • 25 Answers
SOURCE: have a multip speed dremel 350
clean the slots that hold the brushes, sometimes they get cloged and the springs do not push the brushes all the way to the armeture.
Posted on Aug 19, 2008
rowdy45176
  • 2176 Answers
SOURCE: Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Posted on Dec 24, 2008
SOURCE: dremel 400 xpr stopped working.
It could be the fuse between the brush and variable speed control switch. I have the same problem and found the fuse blown. I am hoping that I can replace the fuse without having to buy the complete speed control unit which is about $17.00 from Dremel. If yours is still under warranty you could send it back. If I can find a fuse for mine I will let you know where to get them. joatmontag
Posted on May 24, 2009
Dremel rotary tool variable speed, low speed speeds up after short use. Will brush replacement solve this issue?
How stable is your line voltage? The SCR phase control used for speed control is more sensitive to line voltage changes at low speeds than at high speeds. Brushes should be changed when they are worn down to about 1/2 of their original length. Much more than this and they don't have enough tension to properly contact the commutator ring. Check with power off when the tool is cold and slowly turn the chuck by hand to feel the resistance. Run it a while and let the bearings warm up. Turn off power and turn by hand again. If it feels looser when warm (which would cause it to speed up at slow speeds), the tool might need to be disassembled and bearings oiled. I use Dexron automatic transmission fluid to lube most motors. Wipe down any excess.
Nov 14, 2014 | Dremel Variable - Speed Multipro Rotary...
How can i test if it's brushes or speed switch fault on Piggin Dremel
Problem sounds like the switch. Easy to replace and a lot cheaper than a new Dremel. One other thing comes to mind. Blow out the Dremel with compressed air. I could be to dusty and overheating.
Aug 28, 2014 | Dremel Tools & Hardware - Others
Why does my Dremel run for 1 sec. then switches off If I knock against te side it runs 1 sec before cutting out off
sounds if your tool has a loose or broken brush this is a small carbon object inside that makes motor run, dremel does sell replacement brushes for most of what they mfg. look where ever real dremel bits and tools are sold ck package back to see if your model number is serviced by this brush pack
Aug 16, 2014 | Dremel Tools & Hardware - Others
I was working with the dremel and it shut down and would not turn back on, the motor was not hot. I'm wondering if it has anything to do with the brushes in the side of the motor housing?
My dremel started doing that too. If I rubbed the sanding drum along a piece of wood, it would start up again. I think the brushes and the copper armature get glazed over with non conductive dust and possibly insulation smoke which disconnects it enough to stall out. Change the brushes to the new ones in the kit. After a year of heavy use mine slowwed down to about 300 rpm and then died. A very nice tool but I prefer the Makita which is about three times this size just because it is longer lived.
Apr 09, 2011 | Dremel 395 Variable Speed Multipro Rotary...
Dremel while runnibg cuts out if i wiggle the case or touch the brush cover it starts back up.
Hi it sounds like you have a brush worn out. I would change out the brushes first and go from there. Brushes are relatively cheap and it is a good investment to check out first. You can get brushes from almost any hardware store that sells Dremel parts and accessories.
Jan 30, 2011 | Dremel Variable - Speed Multipro Rotary...
3981dremel I can not find out how to change the brushes or fit them. Where can I have this service carried out in bedfordshire n
you can change the brushes by opening the two little doors one on the top and one underneath the tool and the brushes will just fall out. you can then pop the new brushes in and replace the little doors. if you are looking for where to bye the brushes then just go on ebay or bye from dremel direct. im not sure how much dremel want for the brushes but i paid £7.58 on ebay.
i hope this has helped.
Sep 04, 2010 | Dremel 3981 01 Professional 1.15 Amp...
Will not turn on. Bushings are fine/replaced.
Problem is more than likely that the plastic brush holder got hot with continuous use and the brushes n longer slide smoothly in their housing. Sometimes they even twist a little. The only solution to this is to replace the brush holder-variable switch assembly.
DH
Dec 30, 2009 | Dremel Variable - Speed Multipro Rotary...
Should I be lubricating my dremel (395) tool?
Just a comment-Based on experience, I would go with BOTH their suggestions and order brushes and bearings. That squeal is definitely the bearing; it is a sleeve bearing; RPMs too high for a ball bearing to last and the sleeve bearing has a solid lubricant cast into it.
Dec 16, 2009 | Dremel 395 Variable Speed Multipro Rotary...
My Dremel 395 type 4 does not run until I spin the chuck and then only runs at high speed.
Sounds like a switch or brushes. You can go to Dremel.com and they have a toll free number for their tech services and you can also download a breakdown for this tool.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
698 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
