Question about Toshiba 40XF550U 40 in. LCD TV
Toshiba 40xf550u 40" LCD TV,
4 Suggested Answers
  • 295 Answers
SOURCE: My backlight inverter is fried, how do I fix it?
TV under warranty or not?
Cost more for the labor 90 to 120 than the part which is possibly between 50 to 100
Posted on Nov 19, 2009
  • 1779 Answers
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
Posted on Dec 15, 2009
  • 112 Answers
SOURCE: the backlight inverter board .what can aproblem
An inverter board is an electronic circuit which boosts a low voltage DC current in to high voltage. It's used to power a CCFL tube in he television, which enables the backlight. The inverter, is composed of a MOSFET transistor, acting as a switch, an a coil, which boosts the voltage. The common high voltage output of the inverter board is around 800V.
If your inverter board has gone bad, you could replace the transistor and the coil in the board. This method is the cheapest option, but involves a lot of soldering and time. I encourage you to replace the whole inverter circuit, which is far easier, and not so much expensive.
You will have to take apart the television. Unplug the TV from the power outlet-wait around 8 hours to give time to the capacitor to discharge. Unscrew all the bolts of the back panel, and then, with a plastic tool-like a credit card- pull the back of the screen. After that, you will be able to see the circuit board of the TV. Localize the inverter board, it should be identical to this:
Then unplug the BUS cable and every CCFL tube connectors carefully-they are easily identified with a pink and a white cable. Afterwards, unscrew the fixing bolts of the board, and change it for the new one. You can buy a new one from ebay:
All you have to do now, is to reverse your steps. Connect each CCFL tube, put the back of the television on, screw the bolts and you are done.
Posted on Feb 25, 2011
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
Sep 20, 2012 | Toshiba Satellite L355D-S7809 NoteBook AMD...
Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
Apr 20, 2012 | Samsung LA32B450 32 in. TV
I have a Coby TFTV 4028 and the unit turns on via remote or manually. It goes to channel 3.1(hooked up to antenna) and there is only audio and no picture. I am unable to change channel, volume etc. by...
The tv still new only 1 week old?Yes,return it where u bought it and get a new tv replacement.No?This tv have a 2 long boards that call the LCD inverter boards each sides left and right sides of the tv.Could be etheir one of these two of this long LCD inverter boards it is dead.Must have electronic equipments to test to know exactly with one it is dead.These 2 long LCD inverter boards only job are to probvided a backlight to the tv LCD screen panel to get a pictures.Both of these long LCD inverter boards are not that exspensive and very easily to take the apart and replaced.Tries websites like, to buy both long refurbishes LCD inverter boards for the replacement.
Aug 11, 2011 | Coby 40 TFTV4028 LCD TV
My new 55in sanyo lcd tv has sound but no picture. The tv is one week old. Is the problem the backlight or something else?
Tv only a week old take it back were u bought it,trade it in for another tv.Tv have a picture than flashes only a few sec. than died have sound left only?Yes,than those tv 2 long LCD inverter boards are dead.These tv 2 long LCD inverter boards are only to help the tv to have a backlight for tv LCD screen panel only to produced pictures.
Jul 14, 2011 | Sanyo DP46849 46 in. HDTV
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like, to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
I turn my television on and about not even a minute or so the screen turns black but you can still here the voices so just want to know what is going on.
The tv picture only flashes few mins. than dies,have sound left only wright?Yes,than the tv the 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like, to buy those refurbishes 2 long LCD inverter boards for the replacement.
Oct 12, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Why is my new samsung lcd 32 inch getting on and off again and again it self? and a voice it coming from the back part too.?
Under a year,this tv was bought?Tv still have warrenty,call Samsung for warrenty repair.Not.Tv power on have flashes of pictures,few sec.than dies,have only sound left?Yes.Ur tv have dead 1 or 2 long board call the LCD inverter boards.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produre a picture.Tries websites like, to buy those refurbishes 1 or 2 LCD inverter long boards for the replacement.
Aug 09, 2010 | Samsung LN32A550 32 in. LCD TV
My digistar tv their is sound but no picture...
Ur LCD inverter board is dead.This LCD inverter board help the LCD screen to have the backlight to have light to the LCD screen and get a picture.Tries websites like, to buy a refurbish LCD inverter board for the replacement to get ur LCD backlight back to get a picture.This board is a long board in shape.
Apr 28, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
No picture on Samsung LNS4051D HD TV.
Maybe the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
Jul 24, 2009 | Samsung LN-S4051D 40 in. LCD Television
Toshiba 40XF550U 40 in. LCD TV Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
