Question about IBM ThinkPad X30 2672 Notebook
It started with not powering with the battery now it doesn't power at all and no lights
    President:
  • 3,278 Answers
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on Apr 03, 2011
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
Jun 17, 2017 | 2003 Volkswagen GTI
Is it the battery or the alternator
All the battery does is supply power to the starter to crank the engine over. The alternator doesn't start working until after the engine is started. It supplies electrical power to the engine after it has started and also recharges the battery. If the engine is cranking over but not starting it is neither the alternator or the battery. Check for spark and fuel pressure your most likely missing one of these.
Aug 07, 2012 | 2003 Oldsmobile Alero
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Will an E-Systems 2512 Laptop refuse to start if its the battery is defunct
Take the battery out and try starting it with the power cord only. If it starts then there is your answer. If it doesn't start then either your power cord/charger is dead or your motherboard is.
Jun 19, 2012 | Computers & Internet
Have a toshiba satellite a305-s6853 and it wont power up is thier an internal fuse
Remove your battery plug in your a/c power - you should get a power led light on your unit - if not power led try your power pack on someone elses toshiba or try there power pack on yours - if a good power pack starts your unit then refitted the battery whilst its running and left it charge - that means you have a dead power supply - if it doesn't respond with and alternative power pack your d/c input cct has failed. new m/board.
Jul 10, 2011 | Computers & Internet
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
I have Toshiba Satellite 2455-S305 notebook. The notebook doesn't start. Power light flashes orange with constant interval about 1 sec. Display remains black. When I remove all memory modules power...
The problem you are having is most likely from having a bad battery. Simply replacing it could fix your problem. It could also be due to a bad power cable that is not giving the correct voltage. Here is a link to the user manuel that explains this and any thing else you may want to know: User Manuel
I hope that this helps you!
HelpDeskMan
May 22, 2011 | Toshiba (P000369080) Motherboard
Hi My Dell M1530 doesn't start up The battery is fully charged, the power cord is working good(the light is on) but the laptop doesn' give a sign that is connected to power
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 18, 2009 | Dell XPS M1530 Laptop
IBM ThinkPad X30 2672 Notebook Logo
137 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
