Whirpool Ultimate Care, Heavy Duty, Super Capacity Plus IMPERIAL 9 - cycle, 2 Speed Motor Quiet Wash, Model # LSQ9244EQ0 When the wash or spin cycle engages; can hear spin/clicking sound, during the wash the implier doesn't turn and during the spin the tub doesn't turn. First can you tell me if this a transmision drive machine or belt.????
robocop
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
  • 278 Answers
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Posted on Oct 16, 2009
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    TheMobilian
    • 8220 Answers
    SOURCE: Ultimate Care II washer will not agitate or spin
    Your lid switch could be the problem. It has 3 wires: black red which are hot and green which is ground. Unplug that lid switch and check for continuity between black and red with the lid shut. This video shows where the lid switch is located
    Posted on May 08, 2010
    What causes it to stop intermittently?
    http://www.appliancepartspros.com/whirlpool-motor-2-speed-wp661600-ap6010250.html
    WP661600 is the motor part number for most of the Whirlpool Ultimate Care Washers. Your motor has a internal thermal protective fuse, which will open up, then re-close after a certain amount of "cooling down" time for the motor. You may want to wash smaller loads as to give the motor a break on amperage draw. the cost for the motor is around $125-$145. Also, check the timer for burn contacts.
    Apr 03, 2017 | Whirlpool Washing Machines
    Fix rinse cycle
    That sounds like a failed mechanical timer. Replacing that should solve your problem.
    Dec 13, 2014 | Frigidaire Washing Machines
    I have a whirlpool ultimate care heavy duty super capacity plus imperial 9 cycle washer and after bringing it home from my moms house in -20 weather after installation it leaks from bottom. What do i do
    Hello mcc... It is possible with temperatures that low to have a water filled component freeze and crack. In order to determine if that is the case, go to searspartsdirect.com and enter your model number.
    This will provide you with free schematics of all of the components of your machine. This way you will know what you are looking at when you pull the machine out from the wall, and inspect it. Joe
    Thanks for choosing Fixya!
    Jan 13, 2011 | Whirlpool Washing Machines
    My washing machine won't spin!
    as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
    Mar 13, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
    Washer spin & gurtitate no working
    Coupling is broken that connects motor to transmission. Replace it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
    Nov 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Won't spin or agitate
    coupling.between motor and gearcase.
    Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    I also need the answer...
    Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
    Oct 03, 2007 | Kenmore 22422 Top Load Washer
    Agitator
    if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
    Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    70 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
