Edimax br6204wg wan led doesn't light up and there is no internet connection
    Guru:
  • 868 Answers
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Posted on Apr 03, 2011
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
I lose cd edimax br6204wg
hi do you need edimax br6204wg for configuring router? you can download from there sites
Apr 26, 2011 | Edimax BR-6204WLg Router
How to use edimax br6104k with an smartbro isp
It's not a problem connecting to internet if your isp is smartbro, esp. if you are using a D-Link router..just plug in ur smartbro rj45 to the WAN port and connect ur pc to one of the 4 LAN port of the router that's all you can connect to internet..first time of course u have to input the username and password from smartbro in order to connect again..
May 20, 2008 | Edimax BR-6104K Router (br6104k)
Page Cannot be Displayed-IE, Edimax Router BR-6104K
Smartbro account is used directly to the computers LAN port, not on the router, One computer should be made as the server, where the smartbro connection is placed... to share the internet connection... you should have another LAN card to share Internet throught the router... "See New Network Connection" you'll see examples of proper connection.
Good luck... Fixya...
Feb 02, 2008 | Edimax BR-6104K Router (br6104k)
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
