Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
No soap spray or water comimg out, how to fix this.
4 Suggested Answers
  • 55 Answers
SOURCE: soap or water will not come out
Several things can cause this.
First thing, I check to see if water is coming out the attachment hose. If it is coming out the hose and not the bottom, most likely you have a clogged heater. The heater is located inside the lower handle and just needs to be taken apart and cleaned out. Fairly simple repair, and it is common.
If it sprays for just a few seconds when you first turn it on and then stops, that's a classic sign of a bad pump, and it will need to be replaced.
If it isn't pumping at all out of both the bottom or the hose, there a few simple things to check. Make sure there is fluid in both tanks. It will not work with one of the tanks empty. Make sure the flat belt isn't broken( there is an access panel on the side of the unit to ger to the belt). The flat belt runs the pump. Both of the tanks have a round rubber gasket that wraps around the valve and they tend to come off and get stuck in the inlet valve of the machine. It just needs to be put back on the tank.
There are numerous reasons why this machine might not pump, but these are a few of the most common ones.
Good Luck
Posted on Nov 24, 2008
  • 3 Answers
SOURCE: System will spray soap, but no water is mixed.
I had the same problem. After 3 weeks of seals belts pump etc. I was ready to give up.
The problem with mine as I suspect with others is the seal on the water tank.
The bottom plastic connector is not high enough to allow the water to flow to the pump.
My solution was to raise the bottom connector 3/16 of an inch.
I did this with a piece of plastic cut like a flat washer or auto gasket material could be used.
The connector must be removed from the bottom by pressing on the tabs. Hope this helps.
Posted on Apr 20, 2009
  • 37 Answers
SOURCE: wont spray soap
Please look at my other posts for this solution
Posted on Aug 29, 2009
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
I have a rainbow aquamate carpet shampooer. I cannot get it to pump carpet cleaner.
If it is the one with the big white water supply tank, it needs to soak with water in it for a few Days, then it may take a little bit of running,(10 minutes at the most, at a time, then let it cool, for 30 minutes in between attempts) while you are spraying water out. Make sure the soap control is on the soap bar with suds around it, and not the soap bar that is crossed out. If it is spraying water, you can keep running it. The 10 minute limit, is only if it is not spraying anything.
If it is an earlier one, it has a clogged soap pick up tube, or the soap control cap thing on the end of it.
If it is the latest big blue one, it never will probably work again. All of them must be flushed out after usage before storage, and the new one must have both, the soap and the water passages on the unit sucked out by the Rainbow vacuum, before it is stored. I have never got one of them to work again, once that it was clogged up, from not being cleared out, like it is supposed to be before storage of it.
If you need more help, let me know,
Ralph
Dec 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Wont spray soap
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Apr 19, 2009 | Bissell 1699 ProHeat Clear View Upright...
My Bissell shampoo machine will not spray either water or soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yuet
Oct 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Soap from dispenser will not release into carpet cleaner.
These are two different problems the first could be a clogged heater soap coagulates in the heater passages and clogs the flow of water to see if this is indeed the problem turn the unit on and try and spray water with the top trigger (floor nozzle) then try to spray at the hand nozzle if you get water at the hand nozzle but not the floor nozzle it is the heater. The hand nozzle water bypasses the heater. Also check the solution or soap tank if you pull it out and there is not red seal on the bottom it may be stuck in the machine and won't create a good seal check to see if it is still in the hole where the tank inserts. As for the unit not turning on that could be a number of issues cord,switch or just over heated. Visit www.stevessewandvac.com for any parts or questions about this machine or any other.
Aug 13, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
1,631 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
