Question about Bosch Benvenuto TKN68E75UC Coffee Maker
Bosch Benvenuto built in Coffee maker is recently producing weak watery brews, instead of thick rich cups it once made. Have changed filter and run cleaning cycles. Nothing has helped. Need to get machine back to producing dark coffee like it once did. Thx
  • dwakins Apr 03, 2011
    Thanks for the comment. I have looked into the bowels of the back of the machine today and it seems the job to access the dispenser - grind mechanism is beyond my abilities. I think I need to call in a professional. Thx
  • 11,800 Answers
The quality of the coffee depends on the amount of actual coffee used - if it's too weak then not enough coffee is delivered to the filter by the dispenser. You will have to take the dispenser apart to see what's preventing it from doing its job - most likely it's clogged and in need of a serious cleaning.
Posted on Apr 03, 2011
  • Azrael SRL Apr 03, 2011
    Ask a quote before accepting the repair - the labor in these devices is extensive and might cost more than a new unit.
Why is there no "Add Water" notification?
The "add water" indicator may have failed. Or, could be failure of some sensor that turns it on.
Dec 01, 2015 | Bosch Benvenuto B30 Espresso/Coffee Maker
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
Bosch benvenuto b30 had for years and loved. Now when use beans the coffee/espresso is too watery and pucks are like sludge after. Works good when use preground coffee .
You have accidentally turned down the brew strength selector, on front of unit just above "clean" and "descale" buttons. Dial it the the maximum. Will grind longer, make more grounds, larger puck, stronger coffee. Or this dial is broken/ wire broken etc. u can disassemble per some other posts on here and check wire connections. I did all that then realized someone had just turned it down. So I turned it to maximum strength and problem fixed.
Oct 15, 2013 | Bosch Benvenuto B30 Espresso/Coffee Maker
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
I get lots of watered down coffee. It brews 3/4 cup but it is so watered down. We have descaled etc. I want a thick expresso like taste. This is on a large cup setting Help?>
HI
When you run a lot of water through just a little coffee it gets water down. Try making 2 meduim cups instead. When they make espresso its 1 tablespoon to 1 oz of water. Your running 6 oz of water through the same amount of coffee, and its going to be weak. Program you buttons for 2 shots to fill your cup and it will be pretty strong.
Jan 25, 2011 | Gaggia Syncrony Espresso Machine
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jul 16, 2008 | Gaggia Titanium Espresso Machine
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Bosch Benvenuto TKN68E75UC Coffee Maker Logo
166 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Andrew Taylor
Andrew Taylor
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
