Question about Sylvania LC370SL8 37 in. LCD Television
I have sylvania ld370sc8 when you turn it on vertical line on left side after a hour clears up
  • 53 Answers
SOURCE: Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Posted on Mar 28, 2008
bestdarngood
  • 3037 Answers
SOURCE: sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where your problem is coming from but most likely it will be the power supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c flipping off and on and current demand being peeked from the utilities storms or quick power loss off and on can cause problems like this to occur
Please let me know if you have any other questions, thanks
Posted on May 14, 2008
SOURCE: the left side of my LG plasma has vertical lines.
It sounds to me like one or more of your buffer boards has gone bad. You will probably have to have it looked at.
Posted on Apr 07, 2009
  • 139 Answers
SOURCE: vertical lines in my sylvania lcd tv
They go away after 10 minutes of what? **** She Wrote? Dancing with the Stars? Or simply being powered On? You have some cold solder joints on one of the PCB boards. Once they heat up they work perfectly. The only way to fix this is to have them reflowed by a tech with a soldering tool or have the board replaced. Good luck! Cheers
Posted on Dec 29, 2009
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
37 inch sylvania ld370sc8
that problem is either the t-con board or video board.
a tv techy should check that for
Aug 02, 2017 | Televison & Video
3" vertical line down right side of tv
Answer depends on model number of set which is not indicated here.
Apr 03, 2012 | Sylvania Televison & Video
After turning on the tv. The screen shows up and down lines across the screen. Can't see much of the picture.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hoping this will help in solving the problem...
Aug 05, 2011 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
The screen is blue with vertical dotted white moving lines ... menu options are psycodelic in color
I hope this will help in solving the problem, and do take care in handling the problem....
Jul 06, 2011 | Sylvania 6626LCT 26 in. LCD Television
When tv is turned on, only half of pic is there (left side)..The right side looks like a bar code, with horz. and vertical lines..There is color behind these lines....After it warms up or a couple hours...
This tv is a standard CRT(tube tv) wright?Yes,than the tv video board have problem with dying capacitors or the main colors decoders IC require resoldering.U have a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders and also understanding basic electronic wright?Take the tv aparts check all those capactors all around the main colors decoders IC for capacitors leakages,replaced all these dying leakages capacitors,will solved this problems.These capacitors alway bulges up or puffing up on it top.That the indication those capacitors are dying and not working to it full capacity.Also resolders the colors decoders IC too.Ur tv problems,will be solved.
Nov 15, 2010 | Sylvania Televison & Video
Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Noreen
Sep 09, 2008 | Televison & Video
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
27" sylvania stereo television
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Jan 26, 2008 | Sylvania 6427TE 27" TV
Sylvania LC370SL8 37 in. LCD Television Logo
209 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
