Question about Taco SR504 Switching Relay 4-Zones with Priority
Taco SR504 relay works well but if turn thermostst up manually but when zone turns on buy itself I get chattering from the relays. can you help me? Thank you Gary
No ignition light 12v relay chatters like mad when key turned to on position removed relay powers it up works fine re fit it chatters again any suggestions more than welcome thanks
Hi, Peter I would love to help you but the batteries in my crystal ball are dead so I need the year, make, and model of your motorcycle please ask your question again and provide this information in the details box or comment section or edit your original question. Good luck and have a nice day.
May 08, 2016 | Motorcycles
Navien combi boiler
call in a plumber. it sounds like it is malfunctioning.
Mar 18, 2014 | Taco SR503-4 3 Zone Switching Relay
Honeywell Strat RTH9580 reboots continuously when connected to Taco ZVC406 transformer
Might be a load that's too heavy for your stat. Consider installing an isolation relay.
Feb 18, 2014 | Taco Zvc406-exp-4 Boiler Zone Control,6...
Car doesn't start. when ignition is turned (new ignition) I hear a relay chatter and my horn sounds intermittely, Battery is new & tested goo
The chatter is due to low voltage. Check all the connections. The battery may have corrosion that lowers the voltage.
Oct 20, 2012 | 1999 Dodge Neon
The turn signal relay is chattering. I replaced the relay but the new one is chattering too.
bad earth or short can cause this
also check all globes operating not shorted internally can check with ohms meter if globes dont light up while relay is chattering or remove one globe at time can help to locate area of concern
Jun 22, 2009 | 1999 Oldsmobile Bravada
Wiring a smart control to a taco sr504 to a honeywell L7248.
Set tempture up some so the water will be hoter.
Mar 18, 2009 | Water Heaters
CAmry Head lights and tail lights off
check innegration relay made to fuse block under dash driverside
Mar 09, 2009 | 1997 Toyota Camry
Wipers and radio quit
The relay is over heating and internally shorting out.
Replace the relay.
Feb 01, 2009 | 1995 Chevrolet S-10 CA Edition
HUMMING/CHATTERING NOISE ON SANYO TV
Confirmation: Lee2fixit's solution also worked on a Sanyo 19" TV Model DS19580with 'buzzing relay'. Chassis carriessimilar relay (Type DG1U 12VDC II TV-5 8A 250V~ also by DEC) at location RL601and a 25VDC 470uF electrolytic cap at C622. After confirming the relay was sound and finding no obviously faultedcomponents tied to it, replaced the cap. Bingo, normal operation and a quiet relay. Will post a follow-up ONLY if the fix failsbefore the rest of the TV .. it's almost10 years old after all. Thank youLee2fixit and FixIt.com.
Jul 05, 2008 | Televison & Video
Taco SR504 Switching Relay 4-Zones with Priority Logo
71 people viewed this question
Top Taco Home Security Experts
Lawrence Oravetz
Are you a Taco Home Security Expert? Answer questions, earn points and help others
