Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
Fan does not work.
I have a Whirlpool ACQ158XP0. This morning I turned it on and the fan started very slowly and there was a wierd humming noise that didn't go away until the fan got up to speed. Also when I cycled through the fan speeds, it doesn't blow like it did yesterday. So I turned the unit off and started it again in turbo and it made the same noise and started slowly like before but then the noise came back the fan slowed down and stopped. I believe the compressor is fine because I could here it run and the copper lines were cold. Thanks
  • ottjl Aug 06, 2008
    what can cause a capacitor to go bad?
I'm working on one right now and I believe it's the capacitor. It's hard to find this capacitor. So far I've tryed 3 HVAC suppliers and none have this rare capacitor. First UNPLUG THE UNIT. Take the phillips screws out of each side in the front. Then take the 3 screws out of the face of the control. There are 3 white common wires and a dark brown compressor wire and a light brown fan wire. Take the 1/4 inch screw out and unplug the wires and find another one.
Posted on Jul 02, 2009
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Ac started chripping then fan quit
Sounds like fan bearing gone. New fan?
Jul 04, 2012 | Whirlpool ACQ189XM Air Conditioner
Magic Chef MCO153UBF microwave
There are two things that come to mind, the magnetron is starting to fail, or the strapping has come loose on the fan motor housing, unplug microwave oven and remove top, [several screws] carefully inspect the fan for any loose mounts and tighten.
Jun 09, 2012 | Magic Chef Microwave Ovens
Bottom Oven Fan on Whirlpool AKP951 not working properly
Sounds like the fan is locking up and not turning all the time. If it is a howling sound the fan will have to be replaced.
Nov 29, 2011 | Whirlpool Ovens
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
CONDENSER FAN WHIRLPOOL MODEL CA3030VKA1 2 TOM
check the capacitor of the fan motor.fan motor wiring will be done in parellel to the compressor check the wiring.
May 31, 2009 | Whirlpool ACQ122XK Air Conditioner
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Ceiling fan turns slowly
If you've had it for a few years, the bearings are probably getting bad (dry).
Always start a fan on high---then go to the speed you want, only the high speed windings will handle start-up.
Apr 26, 2009 | Dryers
ACQ 158 XP
unfortunatley the only way to get to the inards is to take the unit out of the window. My fan stopped working also but I found a replacement here
http://www.partstore.com/Model/Whirlpool/Whirlpool/ACQ158XP0.aspx?ModelAliasNumber=acq158xp
good luck
Aug 16, 2008 | Whirlpool ACQ158XP Wall/Window Air...
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
398 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
