Question about Goodman Heating & Cooling
1 BURNER BLOWS OUT WHEN BLOWER FANS COMES ON - Goodman Heating & Cooling
  • 40 Answers
Stop using the furnace now you have a hole in your heat exchanger
I have experienced this recently you have a lifetime warranty on that
unit .but DO NOT CONTINUE TO USE THIS FURNACE
Posted on Apr 04, 2011
My heat kicks on, I can hear it and feel heat when placing hand on vents. However,Nothing blows out.
Blower is not running ? Or is ?if the blower fans not working check fuses or replace motor , if your heat cycles and your blower blows cool air , its likely a heater core issue
Nov 09, 2015 | 2007 Ford Freestyle Limited
Why would a 2001 Volvo S80 AC blower comes on when key is off
HAVE THE STARTER FOR CLUTCH CHECKED,IT MAY BE BRAKING DOWN.
Jun 01, 2012 | 2001 Volvo S80
I have a customer with a evcon direct vent forced hot air furnace. The thermostate calls for heat , the combustion fan comes on then the ignitor lites and the burner comes on for about 2 minutes, jsut...
same thing happened to mine. go on the roof and pull the cap off. mine was rusted thru the inner pipe (exhaust side) letting the exhaust air to get drawn back into the combustion air side. causing it to short cycle or snuff the flame out.
Oct 29, 2011 | Tools & Hardware - Others
When blower comes on it blows cold air.
I need more information about your heater. Does the burner come on and then warm up gradually? If so I would check the burner flame to see how it looks. It should be mostly blue with a little bit of yellow at the tip. Flame shoulb be setting right on top of burner and not be floating . If the flame doesn't look good shut thermostat down and allow time for burner compartment to cool down. Turn gas control to pilot and carefully clean burners with brush or shop vac. with wand attachment. If burners are in very bad shape then you probably need to shut gas off and remove burners to clean.
When your have burners clean reinstall and relight if needed. If you can give me more information I would be glad to help in whatever way I can. Thank you
Dec 10, 2010 | Coleman Heating & Cooling
1998 Cady DeVille fans do not work for ac or econ air. I checked all fuses & relays in the 3 duse boxes w/o sucess. Any ideas?
the fans for the radiator or the blower fan that blows air in the dash? The blower motors are common to go bad.
Aug 27, 2010 | 1998 Cadillac DeVille
Air Conditioner no longer blows
Is the fan blower getting power to it? Check the blower motor fuse to see if its blown.
Aug 06, 2009 | 2000 Acura TL
Air conditioner and heat blower
You will have two fans, one fan blows out the rear of the unit that cools the condenser soil, one blows out the front across the evaporator that blows the cold air out into the room. Some window a/c's have whats called a squirrel cage fan assy. that has one motor that runs both fans. So you either have one bad fan motor (the evap fan motor) or you have a bad fan blade that has fallen off the shaft. Also check the filter see if it is clean.
Jul 30, 2009 | Heating & Cooling
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Blower Motor cycles on & off
whats happening is thje heat exchanger is cooling off and cycling the fan off this is a normal occurance whenever the unit is first turned on.
Dec 22, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
