Question about Cameras
I just brought a new AF-s 70-200 lense and I can't get the lens cap off. It is on so tight - I hate to force it - is there a button I should be pushing?
    Scholar:
  • 43 Answers
You have purchased a very high quality lens that is one of the main optics carried and therefore beat around by working photogs all over the world (I have the same model as well as the slightly less rugged 80-200 f2.8).
Becuase of this there are certain differences in teh lens that may be new to you. If you examine the bezel you will see that it is fully metal threaded even at 77mm and only contains a small rubber O ring. This is done for two reasons. Most importantly the quality of the lens means there si a major emphasis on vibration reduction. This is also why you will notice the lack of an actual apeture ring to bounce up and down, as well as zero external moving parts during zooms or focus.
Second it guarentees a solid mate between a specific filter and the bare lens and you dont risk a minor angle distortion as light passes through both pieces of glass.
While the lenses and filters are metal capped. The lens cap is plastic. It therefore will dig slightly into the much harder and un damagable metal rings. Simply squeez both releases on the cap all the way, twist the cap a quarter turn or so and pull quickly and sharply on one edge. this will like be the only time tha tyou will have to deal with this. Once you re attach the cap later, try to spin it a little bit on the threads themselves. the two peices will mate just fine I promise.
--Jeremy
Posted on Apr 03, 2011
Testimonial: "Extremely helpful and helped me to understand my new lens cap and why it was not releasing."
  • 3 more comments
  • jwtriddle Apr 03, 2011
    I do not know where the two releases are to squeeze.
    This is the rear lens cap - it does not have a release on it like the front lens cap.
    I have been turning it to the left and probably further tightened it - do these turn to the right to loosen? Even turning to the right has not loosen the cap. Very frustrated.
  • martin bishop Apr 03, 2011
    oo haa im sorry. dont do anythign for a second until I understand what you have going on.
    If the lens is seperated from the camera body and just has a black cap on the back end to protect the rear parts than your problem is very simple
    The cap is what we call a left hand thread. in other words if the FRONT of the lens is facing the floor then you need to turn the cap to the RIGHT to remove it. the other reason you are having trouble because of the design of the cap, its molded to grab onto the rear of the lens teh same way the camera does, so what you need to do is actually press in gently on the cap while giving it a twist clockwise. by gently squeezing it you move it just enough to break its lock on the rear lens hinge.
    The cap itself should probably say open with an arrow on it if you look closely
How do I remove stuck rear lens cap for telephoto lens on D3200
Are you sure you're turning it in the proper direction? Nikon lenses (and thus rear lens caps) screw in the "wrong" way. The lens cap turns clockwise to remove.
If it's an ordinary plastic lens cap, as a last resort you could cut it open with a knife.
Feb 01, 2015 | Nikon D3200 24.2 MP CMOS Digital SLR with...
D3100 DOESN'T RECONIZE NEW AF-S 50MM 1.8G LENS
There are a series of small brass "buttons" on the outside bottom of the lens where contact is established. If a new lens, there may be some dirt or grease on them preventing contack. Wipe lens and camera buttons carefully with a lent free cloth and retry. Then it is time to go back to the seller.
Mar 31, 2014 | Nikon 50mm f/1.8 AF Nikkor Lens
Hi where can i get instructions on how to use my nikkon 50mm prime lens?
That depends on the lens in question.
50mm f/1.8 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50mm.pdf
50mm f/1.4 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50f1.4D.pdf
50mm f/1.4 AF-G:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AFS50G.pdf
May 24, 2011 | Nikon 50mm f/1.8 AF Nikkor Lens
I am trying to mount the AF f/1.8D 50mm lense on my Nikon D90- I do not here the click sound - when I turn on the camera, in the view finder I see F-- flashing all the time in any mode. Can you help me...
This particular lens is known to be a tight fit, especially when new. Most likely you just need to turn the lens a hair more and a little bit harder than you normally would in order to have it "click" home.
Dec 18, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
D3000 Digital Camera with 18-55mm lens: hi,i brought a nikon 3000 , is it compatible with ...
ALL Nikon AFS branded lenses are compatible with the D3000. The AF lenses are usable in manual mode. Sigma, Tokina and Tamron lenses without the built-in motor are manual mode as well.
To be sure, check the manufacturer;s websites.
Hope this helps,
Andrew
May 18, 2010 | Nikon D3000 Digital Camera
Nikon Cameras specification.
Some charts are on the web. Search for your model of camera and compatible lenses.
Sep 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have 2 quantaray lenses which I brought with my 35mm SRL are these lenses compatiable with Digital SRL cameras???
Which type of lens mount, what digital camera.
Nikons will fit older Nikon lenses.
Canon it seems only fits AF lenses
Olympus digital only takes their own new mounts.
Minolta lenses will fit the new Sony/Minolta digitals.
Pentax digital will take any K-mount or older thread mount. Need to change some menu setting though. Need a K to 42mm for the thread mounts.
Mounts are all different, so a Canon won't fit a Nikon, Sony or Pentax and vise versa.
Jul 04, 2009 | Cameras
Sigma 70-300 AF lense
if the lens is the older type with a macro switch which has 2 screws holding it on to the lens it will not work.If it a super 70-300 you can put the camer on AV set iris to F22 if you have a stopdown button see if the lens stops down it ok if noe it will need a rechip or a new interuper
Sep 27, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sep 19, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Cameras Logo
118 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
