Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Hello when mowing i have to run full throtle to get blades to spin fast enough to cutt good 24 hp 46 inch cutt
  • 2,841 Answers
You do not have a problem. Air cooled small engines are designed to be run at full throttle in order to mow correctly and to cool the engine properly. Running it as less than full throttle will cause the engine to overwork and possibly overheat thus shortening it's life. It will also not cut properly as you have found. The engine has a governor that prevents you from running it too fast. Run the engine at full throttle at all times when you are mowing which is the optimum speed for proper operation. You may think you are helping your engine by running it slower but in reality you are harming the engine. It is air cooled, not water cooled, and needs the revolutions in order to cool itself properly. Also use 100% synthetic oil in this air cooled engine for more protection. Change your oil/filter once a year or every 50 hours.
Posted on Apr 03, 2011
Polan selfpropeled mower the blade is not spinning fast enough and hardly cuts the grass
Blade speed equals engine speed. Check your carburetor and fuel pipe
Make sure you sharpen the blade with - this is more important for a good cut.
Mar 19, 2014 | Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Change blades on riding mower
Your owner's manual should give you full instructions on removing the mowing deck from your tractor....once it is off, should be a simple matter of turning the deck upright and removing the bolts which hold the blades to the spindles and replacing the blades..... ;-D
Jul 17, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
46 inch cub cadet mowing deck need diagram for belt
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Jun 11, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
Apr 06, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mowing
I did the same thing. I replace the belt that turns the blades. The pressure of the impact had stretched the belt and was slipping on the pully that engages the blades. Try that first and check the other belts for tension, wear and condition....Also make sure all springs are attached, not stretched, and in good shape...Hope this is helpful....Joe
Dec 08, 2008 | Husqvarna 22 Hp 46" Deck Yard Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
