Question about NEC ND-2500A DVD±RW Burner
My nec nd-2500a cannot read DVD+R - NEC ND-2500A DVD±RW Burner
  • NEC Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 03, 2011
5 Suggested Answers
SOURCE: DRIVERS CD-ROM NEC DVD RW ND-2500A
WINDOWS CANNOT LOAD THE DEVICE(DVD ROM) FOR THIS HARDWARE MAY BE CORRUPTED OU MISSING (CODE39)
Posted on Aug 04, 2009
likwidstate
  • 17 Answers
SOURCE: NEC ND-6500A DVD±RW DON'T READ CD
I have encountered this problem numerous times and, while I'm not sure of the exact cause, the remedy that works 90% of the time for me is to create a 1:1 solution of isopropyl alcohol & distilled water and to GENTLY brush the laser with a cotton swab tipped with this solution.  Afterwards, use the other side of the swab to completely dry off the laser, ensuring that absolutely no cotton fibers are left behind.  Good luck!
Posted on Oct 31, 2007
  • 214 Answers
SOURCE: NEC DVD_RW ND-2500A will only read and burn DVD's, not any type of cd
You could try updating the Driver.
The driver and instructions can be found here:
http://www.opendrivers.com/driver/214402/nec-nd-2500a-dvd+rw-firmware-1.06-free-download.html
Have you contacted the manufacturers site and a)checked out their FAQ's and in the last resort Contacted their Support for help?
Posted on Apr 25, 2008
bob_computer
  • 3153 Answers
SOURCE: i only can write with 4x maximum while dvd could
DVD burners will only write to the maximum stated.
Also if you are using 4x DVDs then that is all they will burn at without often giving errors when used.
Trying to burn a 4x DVD at lets say 16x can cause burn failure or data corruption.
Cd's on the other hand can burn at lower speeds than they are stated.
To burn DVDs at higher speeds your burner needs to be capable of that speed
Posted on Sep 06, 2009
It will read audio cd's and film dvd but will not read original xp pro (with sp 2 ) installation DVD
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
Feb 16, 2011 | NEC ND-2500A/GBP DVD±RW Burner
Nec 2500a dvd wont burn maxwell 16x dvd-r
It could be a firmware problem, you can update your firmware but be sure to update to the latest official, stable version. If you have problems only with this type of media and all others are OK, I would recommend you to use different media.
Sep 05, 2010 | NEC ND-2500A DVD±RW Burner
: "WRITER ERROR [ILLEGAL REQUEST (LOGICAL BLOCK ADDRESS OUT OF RANGE)]" Burn4free worked before I rewrote the computer(win XP) .what do I need to install?
You could try and uninstall the drive in device manager, then let the pc reinstall the drive.
Try some other software, i use IMGBURN and CDBurnerXP.
Get back if this does not fix your problem
Aug 19, 2010 | NEC ND-2500A DVD±RW Burner
I need nero 60023 serial no
http://www.esnips.com/usersignin/index.jsp;jsessionid=85D446770588AFC892DDCD4ED57D72F4
Apr 10, 2010 | NEC ND-2500A DVD±RW Burner
I only can write with 4x maximum while dvd could
Sep 06, 2009 | NEC ND-2500A DVD±RW Burner
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
Apr 20, 2009 | NEC ND-2500A DVD±RW Burner
Oct 30, 2008 | NEC ND-2500A DVD±RW Burner
Apr 24, 2008 | NEC ND-2500A DVD±RW Burner
DVD Writer problems
I used the drivers provided by windows XP. What do you mean when you ask about the configuration of my computer?
Jan 14, 2008 | NEC ND-2500A DVD±RW Burner
Cannot burn Memorex DVD-R 16x
I hate being so simple on these questions, but these problems are always a process of elimination. First thing you always do in situations like this - try another brand of disc. Good luck!
Sep 07, 2007 | NEC ND-2500A DVD±RW Burner
NEC ND-2500A DVD±RW Burner Logo
82 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
