Question about Yamaha HTR-5960 Receiver
Powers on and then off when i try to turn it on
  • 269 Answers
Sounds like a capacitor fail. Take it apart and look for bad capacitors. They look like little soda cans. With silver tops. These should be flat . If they are bulging and leaking something or just budging replace them . Remember these have a + and a - side replace them in the same order.
REMEMBER CAPACITORS HOLD A CHARGE SOMETIMES ENOUGH TO KNOCK YOU OUT OR KILL YOU.
Posted on Apr 03, 2011
Computer charges but doesnt want to start up
Remove battery
unplug power cord from laptop
press and hold power button for a least one minute while power cord and battery are removed
insert power cord only
turn on laptop
laptop should turn on without battery installed
if it does not turn on you probably have some motherboard issues
then install battery if it still does not turn ...and try to turn on
it still may turn on...I have seen stranger things happen with computers
you may also want to try another power cord if you have an extra...the power cord may not be allowing enough power to travel thru cord
Feb 15, 2014 | Toshiba Satellite Computers & Internet
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
I have an HP Pavillion laptop (RG279UA) that won't turn on. I tried turning it on with just the power cord and no battery, and I've also tried a different power cord that I know works on another laptop. ...
are there any lights on the laptop when its plugged in like the charging light , does the power ***** have a light on it that turns on if neither of those turn on then its hyour power adapter thats it. if they do turn on msg me back
Mar 15, 2011 | HP Pavilion dv6119us Notebook
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
CANNOT GET TV TO TURN ON
first you need to do some troubleshooting, if you try turn it on with the remote, now try pressing the power button on the tv, check your power cord. Also try to do a power reset by disconnecting the cable from the power outlet, then press and hold down the power button on the tv not the remote for 30 seconds. release it plug it in to the power outlet and try to turn it on. If the issue continues, then your power supply board is damaged.
Aug 26, 2010 | Vizio VP322 32 in. Plasma TV
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
The screen won't turn on. Recyled power and tried
Power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 16, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Compaq presario notebook v6128tu won't turn on
You can try to remove that battery and try to turn it on again.
Sometimes this will happen if that don't work the remove the power supply and try to turn it on.
If you see the blue light around the power input then it's obviously getting power but it's redirecting it somehow which brings us to the battery again heh.
Let me know if this does not work
Happy Holidays
Dec 27, 2008 | HP Compaq Presario V6120us Notebook
Won/t turn on
Hi-
Make sure all the cables are plug in tightly from the back of the monitor going to the PCU or your tower, try using or plugging power cable to different power source as well... Thanks for using fixya!!
Jun 26, 2008 | Computers & Internet
Power
What you should try now is to try and power the laptop while it is ONLY on battery power. If that doesn't work, then pull the battery out and try and turn it on while ONLY on outlet power. If it works while only on battery power, you probably have a failed power adapter. If it only works on outlet power, you probably have a failed battery. If neither method gets different results, it's likely to be a failed component on the motherboard.
Jul 29, 2007 | Toshiba Tecra A3 Notebook
Yamaha HTR-5960 Receiver Logo
231 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
