Question about Technics SA-DX750 Receiver
I CANNOT GET MY SONY TV #KD-34XBR960 TO PLAY THROUGH THIS RECEIVER.
    Brigadier General:
  • 8,546 Answers
TV's don't play through receivers. TV sound might. If it comes from a Cable Box, connect the Cable Box digital audio to the receiver as you would any other high-end audio device; and the Cable Box's standard analog audio to the TV for those times you don't need the Technics audio capabilites (like watching news).
Have you looked at the manuals?
Posted on Apr 03, 2011
Sony KD-34XBR960 has no power; working perfect, on next start up the usual pop when powered on with remote, but failed to come on. No flashing lights, nothing. Unplugged, waited 24 hours, plugged into...
The problem is in the power supply, the most common cause is an open fuse and open capacitors, if the set is more than 10 years old consideration should given in replacing the tv especially if a professional gets involved.
May 15, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
Number FBT
Hello
Number of Horizontal Output Transformer [ FBT OR LOT] for SONY FD TRINITRON KD-XBR960 is,
1-437-523-61
OK
Jan 24, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 that sound like it is
phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
Jun 02, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
Sep 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Dear Sir, Is a 250.00 sony KD-34xbr960 a good buy(mfg date 6-05)? This unit is a sony "factory remanufacture" Thank you Arthur Dodge
Arthur,
Thats is a good deal, these sets last a long time and are very solid. I would have no problem paying 250 for that unit
Jul 16, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
Jun 15, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
TV keeps shutting itself off!!!!
I think the problem with the remote control it malfunction take the remote control away from the tv
and test the tv
I had the same problem and one time the tv came on by itself
now i took the remote control away and testing the tv
now for 15 min. so far so good
try it and let me know
or call sony 1--800-222-7669
email me dnae@cox.net
thanks
Dave
May 24, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Connecting PS2 to an old TV
Plug the Red, Yellow, and White cords into their respective "IN" ports on the VCR. Run a coax line from the "out" port of the VCR to the coax port on TV. Some VCRs require you to tune to channel 3 or "LINE" which is typically the channel before 2 for this to work. To make things easier, you may want to purchase a modulator. This would allow you more easily set this up. The Mini-modulators aren't very expensive and can be purchased at virtually any electonics store.
Aug 11, 2005 | Sony FD Trinitron KD-34XBR960 34" TV
Technics SA-DX750 Receiver Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
