Question about Refrigerators
My freezer is freezing too much even on the lowest setting. The fast freeze button is not active so this is not the cause.. what is likely to be the matter. could it be a faulty thermostat
  • Refrigerators Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Apr 03, 2011
After a recent repair the refrigerator is freezing everything even after turning both freezer and fride down to the next lowest setting
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | Kenmore Refrigerators
The Fridge Section is freezing even though I have the frisge settings on the lowest setting! Jeff Malley 0402 004405 Rye Vic.
I have this same issue on a C410B, also located in Rye .
I think its a thermostat issue, unless yours is freezing only on the bottom of the fridge (which could be a fan circullation issue)
Jan 01, 2011 | Fisher and Paykel Active Smart E522B...
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Belling chest freezer, should the fast freeze button be switched on all the time?? ice-cream an desserts are always very hard when taken out
Hi!!
No, the fast freeze button should only be activated when you load a warm or lots of items at once. It should disengage by itself after a preprogrammed amount of time. If Ice cream is too hard, check your temp. settings.
Good Day!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Freezers
Freezer over freezes,whats the correct setting?
The thermostat maybe defective. It will not over freeze even at the lowest setting.
May 27, 2009 | Refrigerators
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Freezing up
Primary Cause is Thermostate
Secondary Cause only Anti Freez Switch which is attached to the Evaporator Coil unit
Good Luck
Oct 11, 2008 | Miele K8452S Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
