Question about Hotpoint Washing Machines
Hi door handle is broken and the machine is locked ..is ther a way i can open the machine and get my clothes out..
    Scholar:
  • 97 Answers
Hiya
you should be able to release the door by removing the lid and reaching down the front of the machine.
REMEMBER TO UNPLUG FROM THE MAINS FIRST
NOTE
the inside of the machine can be quite sharp so you may get one or two scratches.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 05, 2008
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Zanussi FL884 Washing Machine door lock broken.
More likel that the door latch or handle is broken.
Only way to open door now is to remove the top cover and force the door lock open from inside, you may possibly break the lock by doing this, but there is really no other alternative.
Mar 29, 2010 | Washing Machines
Hi I have broken the door handle off my indesit wd10 washing machine and there are wet clothes inside how do i open the door and fix it
i saw same problem in another brand and it was easy it just open the small door of drain filer then open the filter slowly the water will out into sure small pan under this place you putted then we pull asmall plastic ring hang to ...... open the lock door then enjoy smell .. try this maybe it help .... i try to catch any infomation to you for this m/c but i did not found... thank you
Jun 10, 2009 | Washing Machines
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 14, 2008 | Hotpoint WF430 Front Load Washer
Cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
Oct 21, 2008 | Washing Machines
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Door latch broken, clothes stuck inside!!
not that easy. best way to try is to chew away as much of the handle as possible till the door peg is in view then prise open with a small screwdriver. you can sometimes reach down the inside the machine from the top and feel for the tip of the peg and do it that way
Apr 01, 2007 | Zanussi FLA1001W Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
