Just installed Honeywell RTD7500d thermostat to replace Batstat239 (which seemed to have faulty temperature gauge - it would keep pumping both hot and cold past the set point indefinitely). I followed the wiring guidelines and I am pretty sure I have it right: Trane ----- Honeywell B-----C G-----G Y-----Y O-----O/B __----RC (jumpered to R) R-----R W----Aux X2----E __----L Tan ---- Wire Capped off not used. The Honeywell seems to be controlling only the auxiliary heat, not the heat pump. (ie. the Heat Pump is not running outside when the heat is "on"), so the airhandler is pushing "cool" NOT "cold" air, until the Aux Heat kicks on. From what I have read on-line this could be a fuse, compressor, or other issue with the heat pump, so I am trying to trouble shoot. I have looked for fuses (people have said they look like car fuses) that may have been blown, but not found such an item - although I may not be looking in the right place as the manual I have is rather vague. The outdoor unit is a Trane Weathertron XE 1200 which has a junction box with a large plastic/copper plug that has four prongs - it clearly is marked "no fuse". I have an American Standard Air Handler Model #TWV030B140A1 - which I have read may have some fuse that controls the Heat Pump, but I am not sure where to look. Right now I am looking to find the fuses to check them.... and guidance on finding them would be much appreciated? If that doesn't solve the problem, could someone suggest a next item to check as I troubleshoot?
    Master:
  • Heating & Co... Master
  • 521 Answers
Wiring seems right, but it needs to be wired like the original tstat. Meaning if W was connected to w1 on the old, that's were it goes on the new. If it was on aux heat then your wiring seems correct. If its operating the aux heat "on its own", then that's were your issue is at.(?) Also, there is a configuration menu in the new tstat. It needs to be set up for your system, heat pump, 1 cool, aux heat or 2 heat 1 cool, O should engage the reversing valve(RV=O). If you didn't write down or pic what you started with, it will be tough for you, and us, to wire your unit correctly. And there is no factory installed fuse on the outdoor. The indoor will(should) have a 3 or 5amp "blade" fuse, (car fuse but not the new smaller style, the 80's to 90's style). Its on the indoor circuit board. Hope this helps!
Posted on Feb 28, 2017
louislevel_2
  • 374 Answers
SOURCE: Fan will not shut off, but compressor does
hi! there, continous fan motor when unit was shutt off,since supply source was already cut off specially on fan condenser motor,the supply of your motor was came from relay mounted on your circuit board control panel,there a holding coil to hold the connection between your fan and ac source,shut off breaker for ac unit first before diagnosing ac unit, try to check this out the relay is still activated giving ac source when shut off,the contactor on relay holding your ac supply was shorted,try to check the connection the circuit activating condenser fan relay,eliminate the short circuit,using multi tester test rod,use manual diagram for circuit control board to lessen complicated diagnosing,focus on fan relay ac source then isolate checking the short circuit replace defective relay,contact point of relay are not repairable.take necessary precaution on checking to avoid shock,this a hard task i would suggest that certified ac technician w/ full knowledge of instrumentation should do this.thank's for selecting fixya and have a nice day.
Posted on Mar 30, 2009
  • 252 Answers
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
luker711
  • 91 Answers
SOURCE: I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Posted on Jul 14, 2009
  • 415 Answers
SOURCE: Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Posted on Feb 07, 2010
SOURCE: Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Posted on Apr 21, 2010
Changed thermostat water pump and radiator on my 2001 Buick Century but still keep running hot...what else could be the problem???HELP PLEASE
Check to see if the radiator fan is on when the AC is on. The new thermostat may have a higher operating temperature than the old one. The thermostat could have been installed upside down. The gauge is defective and reading the wrong temperature.
Sep 02, 2015 | Buick Cars & Trucks
98 grand cherokee little heat.heater hoses hot top rad warm bottom is cold collant barely luke warm
While it doesn't seem likely, if you've changed, or had the thermostat changed.... I'd say you got a faulty thermostat. I am curious as to what your temperature gauge says the temperature of the engine and coolant is.. If your gauge is showing hot, I can think of two more possibilities... the water pump isn't pumping right... and, if the water pump isn't working right, the problem can be a cracked head or block, which can cause an airlock in the coolant system. Check the coolant or radiator cap.
Nov 14, 2013 | 1998 Jeep Grand Cherokee
2005 Buick rendezvous heater blowing cold and temperature gauge not working properly?
Faulty coolant temperature sensor and a faulty heater control valve.
Jan 14, 2012 | 2005 Buick Rendezvous
Replaced broken water pump, replaced thermostat, and the temperature gauge consistently sits just below red once it's warmed up. It never seems to go into the red if I'm idling or taking short trips, but...
hi the temp gauge should sit in the lower quarter of the gauge, it has to be a faulty water temp sensor as anything else would cause it to over heat badly
Apr 01, 2011 | 1987 Subaru Gl 4WD
'87 volvo 240 new thermostat, ok for 1 day now overheating again
try replacing your temperature sending unit but first flush your system.after sitting for awhile things have corroded and will cause a restriction
Feb 12, 2010 | Volvo 240 Cars & Trucks
2003 CR-V; Hot temperature gauge
Kind of, it's over heating, probably do to a stuck thermostat in the closed position, have it replaced, and if you keep driving it with it hot like that, you can end up with serious engine problems.
Mar 12, 2009 | 2003 Honda CR-V
Thermostat does not follow the setting
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
857 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
