Tv works fine for 30mins up to 3hrs then shuts down! Ive replaced cooling fans but trying to find location and part# for temperature sensor
    Scholar:
  • 67 Answers
Can you let me know if this is an lcd panel, crt projection or DLP tv. Send me make and model number so I can do further research
Posted on Apr 03, 2011
  • tlncommunica Apr 03, 2011
    model# 60pl9200d/37 brand :philips type:dlp
Engine cooling fan only works when ac or defrost is on
if engine at long stand still,the engine temperature will rise about 190 degrees the cooling fan suppose to automaticaly turn on when coolant temperature sensor get hot it cause its resistance decrease causing pcm to send power to coolant fan relays and cooling fans, when you turn on AC the cooling fans suppose to turn on to cool down AC CONDENSOR, IF NOT AC WONT WORK COOLING FAN COOLS DOWN REFRIGERANT SO IT CAN RECYCLE THROUGH THE SYSTEM AGAIN.your cooling is suppose to turn on when engine at a sit still if vechicle not moving as coolant temperature rises at a set point the cooling fans will turn on cool down engine.cooling fans dont turn on when you first cold stsrt vechicle unless you have AC SWITCH ON.if cooling fans dont turn on when vechicle at a long stand still or moving along slow traffic.if coolant temperature sensor been replaced and fuses and relays okay have dealership check see if pcm driver circuit working faulty pcm will cause cooling fans not to turn on.
Sep 27, 2012 | 1996 Buick Century
Why won't my cooling fan turn on?ive checked the
ive been told that the cooling fan wont come until it gets hotter then mid range
May 09, 2012 | Honda Civic Cars & Trucks
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Samsung hl-s5087w.... Tv is 4.5 years old, and is about 200 hours into its 3rd bulb. Yesterday, very similar to when the bulbs burnt out, it shut off. I thought that it may be getting too hot, so after it...
Above the light is a temp sensor with a blue and white wire plug. This sensor is the problem for all these shut downs in my opinion. Pull out plug and jump it with a wire or paper clip bypassing sensor. Tv should work now!!!!
Apr 23, 2011 | Samsung HL-S5087W DLP TV
Sony Dlp, 46" shuts off, cools off, then turns
This is probably a heat issue (assuming you aren't the one turning off the TV and aren't having regular power failures). This TV has two fans to help keep the components cool; if the temperature increases, the TV will shut down to protect those components. Also check if the ventilation slots are blocked and clean the dust off them. (When you have the TV open, you can blow out dust as well - much like dust removal for a desktop CPU.)
For replacement fans, you can go here: http://www.partstore.com/Model/Sony/Sony/KDF46E2000.aspx .
I hope this helps.
Nov 01, 2010 | Sony KDF46E2000 46" Projection HDTV
I turn on my hitachi 50v720 tv it runs for 5 minutes shuts off and the temp light comes on.what could be going on?
It's most likely the cooling fan is not operating either due to the supply line for the motor missing or the fan itself at fault. This means when the lamp reaches a certain temperature (after 5 minutes) the temperature sensor should then active the fan to keep it cool, if this does not happen it will go into protection 7 shut down.
Sep 16, 2009 | Hitachi 50V720 Television
61" samsung DLP 3 years old. Keeps turning off by itself.
Get a small but powerful used computer fan and place it in the TV to replace the defective old fan.That's the best way.The factory fans in these TVs don't last.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Sony VAIO GRT170 laptop fans wont run.
Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Nov 03, 2008 | Sony VAIO GRT170 Notebook
Cooling fans
it wont be a fuse it would be a relay and ive never seen them fry before. It's probrally a heat sensor that tells your fans to turn on at a certain temperature
Aug 13, 2008 | 1992 Pontiac Grand Prix
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
