NO SOUND AT ALL AND THE THERE IS NO SIGNAL ON THE SYSTEM CHECK have checked the scart leads they are ok
  • pat_vins Apr 03, 2011
    the tv sound is ok it is the sky sound that has gone
    Scholar:
  • 67 Answers
Can you let me know the make and model for this tv.I will need this information to do research. Have you gone into the sound menu and have the speakers turned on?
Posted on Apr 03, 2011
Phillips DVD recorder connection issue?
SCART is designed to carry analogue standard definition content. So if the input signal is high def. it will distort.
Jun 09, 2014 | Philips Televison & Video
Philips DVD player no sound
Are you using a scart lead to connect to tv try changing lead as some times scart leads don't have all the pins I prefer to use scart leads that have all the pins in them and make sure they are firmly pushed home also check settings on tv as some tvs allow you to mute av plugs
Apr 10, 2014 | Philips Dvd Video Player
Screen has gone white
Only two things, a fault with the signal coming in or a fault in the TV itself. Check your cables, particularly scart leads are prone to being damaged. If the cable is ok or there is no signal on ANY of the input signals (tuner, dvd etc) then the TV is likely faulty.
Dec 19, 2010 | LG Televison & Video
Sound but no picture
ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
Feb 06, 2010 | Televison & Video
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
With my sega megadrive11 system when tuned in only sound comes no picture
Hi Wisebear,
First It maybe your TV not tuning in properly.
to try this go to your TVs Tuning menu and select manual tuning and fine tune around the sound and see if this helps...
second it may be the lead (worn wire) and not enough signal getting through, so you need a new cable
you may just want to upgrade to a scart lead
www.retro-cache.com
sells the scart lead for Megadrive 2's and soon will be doing Megadrives 1's as well, both RGB.
Jun 27, 2008 | Sega Genesis 2 Console
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
Samsung home cinama
Most likley your scart cable is the culprit, check whether the scart cable is the AV I/O type. And also better check the audio settings of the DVD player. Hope u hook up the speakers correctly. Cheers, Rifaa
Sep 04, 2007 | Samsung HT-Q100 System
Picture ok but no Sound on My Bush Internet TV.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 11, 2017 | Vutec Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
