Question about Canon PIXMA MP620 All-In-One InkJet Printer
Canon Pixma mp780: jammed cartridge display but no apparent paper or other jam
  • 142 Answers
Turn on, lift cover, open front, and gently slide cartridge left and right sereral time, not touching the thin film or silver guide bars.
Posted on Jan 25, 2009
Paper jam in canon printer mx432
I took Ekse suggestion to start off with by turning off the printer; opening the front cover and removing the ink cartridges. Behind where the color cartridge goes is a light blue wheel. I took a letter opener and gently tried to move it. It moved and after a few turns it loosened the paper and I was able to gently removed the whole sheet of paper. I'm by far a techy but have been known to take care of paper jams. This little machine had me baffled because the back was of no use like other machines.
Jul 05, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
i have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Nov 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
MP780 "check printer"
5200 is a printhead error, you may just need a new printhead. They do wear out, and just like a light bulb, they go out when you least expect. The part number is QY6-0049-000.
Jan 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Machine thinks there's a paper jam
ok what you have done is when you have pulled the paper jam out you have either still have a small piece of paper over the sensor or you have broken the sensor itself it sounds like the later, most people tend to pull out the paper backwards against the feed rollers and sensors just below the feed rollers and it causes the sensor to fall out or break i have seen this so many times,
canon tech
Apr 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MP780 paper jam
You need to open up the unit as if repalcing a cartridge and get a torch and really look hard for the jam it can be really tiny. Look in and under cartridge roller (paper roller too) and is the cartridge aligning itself when you open the unit so thta acartridge can be changed? Good luck.
Nov 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP620 All-In-One InkJet Printer Logo
202 people viewed this question
old marine
old marine
