Question about Docter Riflescopes Classic 6x42 Plex Reticle Rifle Scope Riflescope 55101
I have a Valor 4x32 #20244 Nitrogen Filled Luma Glo Rifle Scope that is missing the windage and elavation "caps only". They were lost over the years and I need a source to purchase them..any suggestions
Diana scope 3-9x 40 AO - I need a parts diagram and how to find spare parts to it. In a 'just in case mode' (Magnum airgun recoil) what spare parts should I have to this scope?
Hi Marcos
You will probably not find any spare parts for the scope, unless you will write or contact the manufacturer of the scope.
I do not recommend that you repair the scope yourself, as it has to be reinstalled properly and also most are nitrogen filled to stop fogging of the lenses.
Make sure you only use a scope that is designed for an air rifle, because the spring pushes and pulls the gun when it fires and it has to have the "air rifle" scope to handle the double recoil if not you will break the reticles of the regular gun scope.
Bud
Oct 18, 2013 | Garden
How to disassemble my bushnell sportsman rifle scopes coz i wnt to clean it
On my Bushnell scope I have an adjustable angle ring that will bring in the view, it is held in place with 1 screw. remove it and pull down towards the windage and elevation adjustment screws. There are 3 tiny phillips screws, remove them. Then unscrew the end of the Eye Peice end peice with the lens in it. inside on the outer edge of the main tube there is a locking ring that keeps the eye peice from unscrewing off, remove it and unscrew the entire eye peice. you are now ready remove the inner tube. Be careful here this is where you can damage the cross hairs and lose the leaf spring that maintains pressure against the windage and elevation screws. When you reassemble after cleaning and with the elevation screw at 12 o'clock and windage screw at 3 o;colck, the leaf spring will be in the 7 or 8 O"clock position, it just sits in there up against a little ridge inside, with the bow facing to the center. Back off the elevation and windage screws all the way so they don't block the inner tube from going in all the way. Once it is in adjust it so the cross hairs are orented correctly and put it back together. If you want to refill with Nitrogen remove the front lense and take to someone that fills tires with Nitrogen and inject the nitrogen into the scope, Quickly reinstall the front lens as nitrogen is about 3% lighter than air and if you take too long it will all escape.
This worked well for me. Good Luck and Happy shooting
Apr 27, 2011 | Bushnell Sportsman 4x32 Riflescope (4x32...
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
I have about a 1989 model Leupold 3x9 Var X and lost the users manual- it is shooting about 2-3 inches to the right at 60 yards- Can you tell me which way (lft or right?) and how much- I assume I should...
You have a number or a fraction on the inside of the windage cap, or you should, it will say something like 1/4 or 1/2? That will tell you how many fractions your scope moves with each click, at 100 yards. Anyway, there is also a left and right direction on the scope, you want your scope to go in the direction of your bullet miss, this will pull the barrel over to the center, again, it is supposed to. If you have run out of clicks, you will need to shim your scope. So, on the 1/4 inch at 100 yards, you will want to move the dial, 8 to 12 clicks to the right. Shoot it again, if it went the wrong way, you know what to do. If it didn't move at all, try this.... If it is a bolt action rifle, pull the bolt out, mount the rifle in a cardboard box with v grooves cut in it so it will cradle and not move, or a vise, sight down the barrel at a target at 100 yards, then peek down the scope, it should be right on the target, if not move the cross hairs till it aligns, check the barrel again, make sure it didn't move, then peek through the scope again, if it is the same, it will be on paper at 100 yards, if it is not a bolt action, the only other rifle you can d it with is an AR type rifle. This is a military trick, not something I dreamed up, it works. Check it out.
Nov 11, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Nitrogen gas refilling in a rifle scope.
At a factory, the scopes are emptied in a vacuum chamber and nitrogen gas is used when the chamber is allowed to repressurize to the surrounding environment.
One possible solution is to re-assemble the scope in a clear plastic bag filled with nitrogen gas (working through the bag to re-assemble). Large plastic gloves can be taped into the sides of the bag.
Nov 13, 2007 | BSA Big Cat 3.5-10X 42mm (3.5-10x42 mm)
Lost caps
I'm not sure how this got posted in the car audio section...
If the scope was manufactured by a well established company, you should be able to get a new cap from them.
If you cannot locate the manufacturer, you can move the other cap to the windage adjustment to set the windage. Then when you're finished, move the cap back to the elevation adjustment.
Even if you use it for a shooting discipline that requires constant adjustment, it's unlikely that you'll need to use the windage adjustment for anything other than setting the zero.
Oct 16, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Docter Riflescopes Classic 6x42 Plex Reticle Rifle Scope Riflescope 55101 Logo
538 people viewed this question
Top Docter Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Docter Optic Expert? Answer questions, earn points and help others
