Question about Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
My dell inspiron webcam is not working, it was working before but ever since i formated my hard disc, my cam stopped working, whenever i try view other ppls webcam it will not bring the box not to talk of showing anything and same thing goes with when someone is trying to view mine too. please help me out
  • 90 Answers
Install DELL web cam managing software came with the system driver or download the same from DELL driver downloads.
Posted on Apr 03, 2011
    Sergeant:
  • 378 Answers
You will need to get the proper drivers for the camera to work. You can get them easily by visiting www.dell.com and go to support, select your computer model and on the left side of the screen there should be a tab for Drivers. Find the one for your computer, download and run it. This should enable the camera.
let me know if you need help, I can help further and even possibly help by logging into your computer and fixing it for you.
- Mark
Dell Web cam does not work on Insprion 17
if new system, factory defect on web cam, hope for warranty cover for free replacement , parts and service, else if web cam used to work then stopped , reinstall driver for webcam, all else fails replace web cam
Dec 28, 2012 | Dell Inspiron 17r N7110 Laptop 17.3" 679gb...
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
Microsoft webcam driver
Make sure you've installed the disc properly. Check on the manual that it works on the formal your computer/laptop is e.g. vista, xp ect. If it supports it then check all your properties are working if all properties appear to be correct try going on "My computer" then on the cam and then trying to view your cam. If that works then go onto the top options until you find a button that says options then check to find what your formats in. By clicking on options you should be able to change your format.
Apr 04, 2010 | Microsoft LifeCam VX-1000 Webcam
Dell inspiron 17" webcam not found by computer
the cam should have an istalation disc reinstall with the disc that should solve the issue
Sep 28, 2009 | Dell Inspiron 1720 Notebook
On msn, my webcam shuts off before someone is able to view it. out of msn it works fine, i have a dell inspiron laptop with an inbuilt webcam, anyone know how to solve my issue?
you need to uninstall all the drivers that the built in camera has in your computer... then try re installing the drivers back again... you should have the cd from the time you bought your laptop...
hope it helped you... tnx
Jun 07, 2009 | Dell Inspiron 1420 Notebook
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
Dell inspiron's USB ports can't detect webcam
Try a different USB device...see if the PC detects it.
If other devices, like a flash drive run, then your web cam is dead. You can try the web cam on a friends computer to see if it's ok.
If the web cam is good, and no USB devices work in your USB slot, You can check the USB controllers in the "Device manager"
right click "My Computer"
select "Manage"
select "Device Manager"
Click the + sign for "Universal Serial Bus controllers"
Do you have any errors?
I hope this points you in the right direction...Good Luck!
Apr 06, 2009 | Dell Inspiron 1000 Notebook
Problem with my webcam on my Dell inspiron 1525 laptop
Your Dell is under warranty. Contact Dell and have them honor the warranty.
Mar 31, 2009 | Dell Inspiron 1525 Notebook
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
201 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
