Question about Refrigerators
MY REFRIGERATOR NO FROST - Refrigerators
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to have a detailed idea related to your issue as to why your refrigerator wont frost:-
http://www.appliance411.com/faq/howdefrostworks.shtml
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 03, 2011
Is my Dometic refrigerator/freezer suppose to be frost free?
Hi Mrs Sandy! With regards to your concern, I believe that specific model of Domestic Refrigerator is not exactly a "no-frost" fridge, although it has a technology to reduce or prolong the time before it actually accumulate "frost" in its cavity.
Sep 22, 2014 | Dometic RM2652 Refrigerator
Is FRG-1820BRW frost free
Most of the newer models are all frost free.
Nov 22, 2012 | Daewoo FRG1820BRW White Top Mount...
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
I HAVE A KENMORE COLDSPOT 106.56542400 MODEL.THE REFRIGERATOR DOES NOT GET COLD AND BOTTOM FREEZOR SECTION FROSTS UP.IF I UNPLUG REFRIGERATOR FOR A DAY,EVERYTHING WORKS OK FOR ABOUT 2 WEEKS AND THEN...
We had the same thing and the problem was the frost sensor on the coils inside the freezer. It is behind the metal cover that gets all frosted up. When it works it senses frost on the coil and tells the control panel to activate the defrost wire which heats up the space melting any frost and then shuts off.
Our issue was the frost sensor but it could also be the heating element or the control panel. Anything in that little system.
Sep 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Frost in freezer refrigerator not cooling
see this ..http://techie-doc.blogspot.com/2010/09/fixing-refrigerator-problem-frosting-in.html
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No frost not freezing.not cooling as well...lg ref no frost.
check this out http://techie-doc.blogspot.com/2010/09/fixing-refrigerator-problem-frosting-in.html
Dec 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
My frost free refrigerator has frost even with
your freezer is getting frost because the door is not closing all the way. Make the necessary adjustments to the door so that it gets a good seal and the frost should stop
Nov 04, 2009 | Refrigerators
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Is there a way to disable the frost-free feature on amana freezer
If you disable the frost free feature you will have to defrost every 10 days.
But, yes,it can be done.
Aug 05, 2009 | Kenmore 53542 / 53544 Side by Side...
Refrigerator conversion.
Forget about it. Frost free refrigerators are engineered to be exactly that.
May 09, 2008 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
