Question about Fellowes Office Equipment & Supplies
I have a Fellows Shredder model JB01 DS - 1 050916 V A 0066447 CRC 30110. No idea how old. Forward/Reverse switch is bad. Sensor in center will not stay up. Runs great in reverse but will not run forward. Is it worth installing a new switch? Motor seems OK. Please advise cost to repair. Thank you
  • 883 Answers
SOURCE: Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Posted on Jun 21, 2007
  • 13433 Answers
SOURCE: Identity Guard Model: SH9210PL
Do you have warranty? get it warranty repaired - replaced.
Let me know if you don't have warranty.
Posted on Jun 08, 2008
SOURCE: Model: SH9210PL
sensor is dirty. clean the sensor. it is located approx. 3 inches from left side of paper slot, 1 inch below top.
Posted on Feb 22, 2009
Testimonial: "I got this reply long ago & it worked perfectly. I was a new user & obviously did not do every thing necessary to remove it from my question list. "
sparkysbox
  • 61 Answers
SOURCE: Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Posted on Mar 13, 2009
JayBlair
  • 328 Answers
SOURCE: durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
I have jb01 and can nott see any sensor no light no switch
There are 2 methods. One is a mechanical arm that is lifted by the paper.
More often there is an LED light at one end of the ffeed to the cutters, and a sensor at the other end. It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in
reverse.
Mar 15, 2014 | Office Depot Ativa DQ60M Shredder
Our Olympia paper shredder forward switch does not work but the reverse does.
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck..
Apr 15, 2011 | Olympia Office Equipment & Supplies
Works in reverse but not forward
Good luck.
Apr 11, 2011 | Cross Infoguard Shredder SX102M
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
MY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH PAPER.WENT TH SHRED ENVELOPES AND TOO MUCH PAPER WAS INSIDE.hOW DO I UNJAM THIS? iVE TRIED REVERSE SLOWLY THEN FORWARD,ETC.IT IS STUCK BADLY.I SAW AN ANSWER...
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Apr 21, 2010 | Fellowes OD1200 Shredder
I need a main forward and reverse switch for a fellowes ds1 shredder.is that possible?
Have you tried calling Fellows? This link is to your operating instructions, which has phone numbers listed for different countries.
http://www.fellowes.com/Fellowes/Materials/Documents/ds1_2005manual.pdf
This link is for listing your model and serial number to inquired about what parts are available.
http://www.fellowes.com/Fellowes/site/support/support_faq.aspx
Dec 03, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellows paper shredder
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Mar 29, 2008 | Fellowes DM8C Cross-Cut Shredder
387 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
