Question about Vivitar V5000AF Slide Projector
I need a rotary carrousel for 3000 AF - Vivitar V5000AF Slide Projector
    President:
  • Vivitar Master
  • 412 Answers
Your best bet is the internet - do a Google search for a new or used one. Be sure to be specific on the brand and model of the projector you need the tray to fit. "Carousel" is a Kodak trademark, and someone looking to make a quick buck might assume you can use a Kodak tray on your Vivitar (which we know you can't). And there's still a TON of Kodak trays out there. Good Luck! Jim
Posted on Dec 12, 2011
Hi,I am unable to remove attachment from rotary drill. no instruction book
For a tool like the dremel you push down the shaft lock button on the side of the bit and use the small wrench to unthread the collet nut.
basic manual, others on page: http://mdm.boschwebservices.com/files/05-11%20100-3000%20r37449v3.pdf
Sep 24, 2014 | Tools & Hardware - Others
Instructions for job mate rotary tool
https://www.youtube.com/watch?v=Fy7Fr0gIwXs
looks just like a dremel
Apr 07, 2014 | Rotary Tools & Hardware - Others
No output
You should start with Rotary switch on "Maintenance Bypass" position and Qf1 open.
Turn Rotary Sw to "Test" position and wait for self test to execute and UPS to turn on.
Once you get the Yellow lamp lit, it is asking for QF1 to close
Once closng QF1, if green LED is lit, turn UPS off by pressing gray button until it ask for confirmation, select Yes and press Return.
Turn Rotary Sw to Normal position, press On button and the green LED will illuminate.
If, after closing QF1, the green LED didn`t lit, turn Rotary Sw to Normal, press On button and wait for green LED to lit.
Thats`it...
if anything is not working well.. please let me know.
Mar 25, 2014 | MGE UPS Galaxy 3000 UPS System
Kodak Ektagraphic AF -2 carousal not rotating
Given the age of the projector, I suspect that the solenoid link is broken. The link joins the solenoid plunger to the cycle lever. The good news is you can still buy parts for your projector. www.micro-tools.com purchased the entire projector parts inventory from Kodak a few years ago. They can also help you with instructions to install the parts, or if you prefer, hook you up with a trained service technician to perform the repair for you. Good Luck! Jim
Nov 28, 2012 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Where to perches rotary Hunt AF-5 fluorescent 6 Amp Electronic Dimmer
I Googled "Hunt AF-5 Electronic Dimmer" and got this result:
http://www.allelectronics.com/make-a-store/item/DMR-50/DiMMer_For_Fluorescent_Lamps/1.html
There may be other sources- such as your local electrical distributor. Good luck!
Jun 26, 2012 | Electrical Supplies
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
Model 760 H projector-- Carrousel advances, but slides do not
My guess is that your slides are in a 140-slide tray.
Over time, with repeated cycles of humidity & drying, slides warp slightly. The compartment width in a 140-slide tray is quite narrow, and it takes very little warping to make slides stick in their individual compartments. If you move the slides to a KODAK 80 Slide Tray you should be in much better shape.
Feb 24, 2010 | Kodak Office Equipment & Supplies
Cd carrousel keeps spinning
This problem is likely caused by either an open fuse or a failed Carousel Index Lamp. The index lamp is located behind the black metal cover on the right front side of the carousel - fits over the teeth. The lamp should be visible under the cover or if you peer sideways from the left front edge of the carousel. Spares are available from us.
This can also be a fuse related problem - if the bubble tubes AND the colour cylinder motors are all dead then first check for open +/-30VDC fuses in the amplifier.
More tech info on my website:
http://flippers.com/wurlitzr.html
John :-#)#
www.flippers.com
Mar 18, 2009 | Wurlitzer Jukebox CD Player
AF mode
Full-time AF keeps the image on the LCD monitor focused at all times without having to press the shutter release button. Note the following: Using full-time AF will drain the battery more quickly Full-time AF is not available when the LCD monitor is turned off For "Card set-up" or "Card cover alarm", the AF operation of the camera does not halt. Once resumed, the camera always puts the AF in action for immediate focusing
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Vivitar V5000AF Slide Projector Logo
133 people viewed this question
Top Vivitar Office Equipment & Supplies Experts
Doberman
Are you a Vivitar Office Equipment and Supply Expert? Answer questions, earn points and help others
