Question about Refrigerators
How do i change the door so it hangs from the opposite side?
  • 126 Answers
I posted some instructions on this yesterday go to search for solution and you should find it there it is and step by step fix: ) if not contact me and i will help
Posted on Apr 03, 2011
How do I change the door on my may tag mah6700aww from right side to left side
I have never seen a machine where you could reverse the door,you would have to move the interlock/door latch too.Normally this is not possible,the cables to the programmer will not reach.
Feb 24, 2015 | Washing Machines
How can i change de side of the door
Most refrigerators have provisions for reversing the door(s). It is a matter of removing the door(s), changing the hinge hardware over to the opposite side, and reinstalling the doors.
Jun 30, 2014 | KitchenAid Refrigerators
How do you change door swing direction?
Refrigerators with reversible doors have mounting holes that are plugged on the opposite side. You have to remove the plug(s), remove the door and its hardware, position the door hardware to match the exposed holes and install the door with the opposite swing. Careful attention must be paid to proper door alignment so that it closes properly and seals properly.
Jun 03, 2014 | Roper Refrigerators
Trying to reverse door swing on Samsung washer WF405ATPASU/AA
Tony, this is a simple procedure and you just need a medium sized phillips head screwdriver. Start by opening the door and removing the two phillips screws that attach the hinge to the machine. Remove the door by lifting up and out. Next, remove the two screws that that you will now see (previously hidden under the door hinge that you just removed). Now, go to the opposite side and remove the two screws that hold the door latch and pull out the plastic latch insert. Also, remove the two screws located (about 4 inches) above and below the latch insert. Now simply reverse the process by securing the plastic latch on the left side along with the two screws (top and bottom). Before securing the door on the right side, lay it down and remove the screw that is used to hang the door (within a slotted hole on the machine) and move it to the top of the hinge (you will see a hole for it). Now simply hang the door on the right side of the machine, and firmly secure it with the remaining two screws. Your door should move freely and latch securely.
Dec 16, 2013 | Samsung Washing Machines
To changedoors from one side to the other. KGV28V00GB/01FD
all you should have to do it unscew the doors and on the opposite side there should be caps, take caps off and move the hindges to the opposite side.
Jan 25, 2012 | Bosch Classixx KSR32623 Refrigerator
Can the door swing be changed?
Yes the door can be changed to open from the opposite side, there are removal plugs that need to be removed from the opposite side and just change all the hardware from one side to the other, change the middle hinge first and put on the bottom door first, after its is mounted you can put the bottom part of the top door on the hinge and last the top hinge, and just make a few minor adjustments.
Apr 16, 2010 | Amana ARB1917CSR Bottom Freezer...
Change doors of fridge freezer from right opening to left opening needless to say cannot find instructions after 10 years
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
Mar 13, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Replace drivers side window switch
Is your question, HOW to replace? you pry it off from the back, closer to the door handle, if you do the opposite (closer to the window) you will break it and then it will not lock into place and it will be hanging. But remove it from the side closer to the door handle and remove the pins that hold the switch to the frame and replace.
Feb 11, 2010 | 1999 Pontiac Grand Prix
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Switching doors to open the opposite direction
Look on the other side of the door and see if there's a plug covering a hole even with where the door handle attaches on the opposite side. If so, I think you just unscrew the handle from the top of the fridge door or bottom of the freezer door an unhook the other end and reattach on the other side of the door. And unscrew and move the hinge to the opposite side. If your doors can be reversed the holes should arleady be in place. It didn't look overly difficult when the delivery guy changed mine when the fridge was delivered.
Nov 24, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
