Question about LG WM-1485FHD Front Load Washer
Mildew smell in towels
I have tried everything but I keep getting a smell left in my clean towels. Any suggestions? I have changed soaps, cleaned as recommended, left door open ALL the time, drying my towels for 2 hours. Nothing is helping.
    President:
  • 1,462 Answers
Are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Posted on Aug 05, 2008
SOURCE:
I have a Whirlpool top load washing machine. lately it really smells. I ran several cycles with bleach to try to get rid of the smell...but it doesnt help. Help...my house smells like a sewer.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa
Jan 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
How do you get the mildew smell out of a clothes dryer?
Very unusual problem with a dryer as it gets hot and would normally evaporate moisture causing mildew!
Try the following:
  • Unplug the power point of the dryer.
  • Gently clean the interior (and exterior) with a super absorbent cloth/non-scracth sponge lighty soaked in a mild bleach soapy mixture to kill off and remove the (blackish) mildew (Nappy wash is not a bad mixture). Weat rubber gloves for protection.
  • Let the unit wet for a few minutes and then using clean warm water and sponge, remove all trace of the bleachy soap on the unit as it is corrosive. Additional drying off with disposable paper towel will help remove any trace of bleach.
  • Put a wet clean bathroom towel lightly soaking with material conditioner mixture at double the normal recommended ratio, power the dryer and dry off the towel as per normal: the fabric conditioner is also a freshner.
  • Musty milldew odour should be gone!
Hope it helps! Please let me know how you go!
Aug 05, 2010 | Hotpoint Dryers
Mildew smell
All front loaders have to be run thru a clean cycle with no clothes or soap atleast Twice a month. You can use bleach or buy one of the special cleaners they have for washers.
Jul 01, 2010 | General Electric WBVH6240HWW Front Load...
Mildew in the tub. clothes now smell.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jun 23, 2009 | Kenmore HE2 Plus Front Load Washer
Nasty mildew smell from washing machine
May 02, 2009 | Washing Machines
Tub has a sour smell &does not seem to be rinsing soap out of clothes
Apr 29, 2009 | Washing Machines
Washer smell
Apr 06, 2009 | Kenmore 24032\24036 Top Load Washer
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Washer door ring has mildew on it and is causing my clothes to smell moldy. What can be done to get rid of this? I've used bleach, and cleaners directly on the rubber ring, but with out success.
Unfortunately, when mold and mildew impregnate the rubber door boots on these models, it's nearly impossible to get it to go away. I would recommend replacing the door boot and follow these diligent preventive measures to keep the problem from coming back: 1. Check the area in and around the door boot after each wash for lost articles of clothing like underwear and socks. Also, clean out any lint or debris that collects under the boot. You might want to think about using a mesh garment bag for small items in the future. 2. Wipe the area periodically with a towel to get rid of the accumulation of soap deposits and dirt. This means wiping BEHIND the door boot where it meets the wash tub as well. I recommend waiting until you get ready to do a load of towels. Clean the area with a towel, then throw it directly in the wash. 3. Leave the door OPEN between washes to allow the door boot to air dry. Due to the nature of these door seals, they seal air tight and create an environment for mildew and mold to grow. 4. Run the washer with no load on the hottest cycle you have with nothing but bleach about once a week to keep bacteria to a minimum, and to flush the drain lines and pump. The door boot costs about $80 to replace, but it may be your only solution to getting rid of the smell and bacteria. Let me know if you decide to replace it. I can give you some pointers.
Jul 28, 2007 | Kenmore 44072 Front Load Washer
LG WM-1485FHD Front Load Washer Logo
309 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
