Question about Garden
North Star Model 157597 Pressure Washer from Norther Tool calims to have adjustable pressure. There is nothing in the manual about how to adjust the pressure and I have received two statements from them on how to adjust the pressure: 1. Adjust the pressure at the unloader valve 2. Run the motor at reduced speeds. Which, if either is correct?
4 Suggested Answers
  • 6 Answers
SOURCE: Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Posted on Sep 08, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Pressure Washer
Derek, Hi and welcome to FixYa. I am Kelly.
I just now happened across your post and note it is 3 months old. Hopefully you already have the problem solved.
If not.. looking at the pump history of having the un-loader valve replaced it sure seems that the current un-loader valve is sticking. When an un-loader valve is removed the internal housing is sanded smooth and everything about the un-loader valve is coated with Lubriplate #105 White Grease. I get the feeling that who ever did the un-loader valve repair failed to sand / clean the housing and use White Grease for the final assembly.
You should remove the valve... Sand the housing and get some Lubriplate #105 white grease (auto parts store) in a tube. Lubricate it liberally and reassemble it. If should work fine after that.
Thanks for choosing FixYa,
Kelly
Posted on Dec 07, 2010
I have a north star pressure washer model 2SFX20ES3 and the pump is not working. The engine is working good. I pull the trigger and no pressure.
Hi
Sometimes you may have to allow a little time for the pump to prime itself and remove the air trapped inside. With the pressure washer at idle and the pressure hose fully extended, squeeze the trigger and see if you get pressure in a couple of minutes.
If you get no joy from that, your pump has likely checked out on you.
Hope this helps.
-Steve
Jun 05, 2015 | Garden
Rtm model 9034 framing manual nailer
Hi, If the tool doesn't have a depth of drive control (Found either by the trigger or, on the safety element) you can get around this by adjusting the air pressure from the compressor. Just make sure that you have plenty of scrap timber to experiment as, when the adjustment has been made, the line pressure is still as it was. Firing a nail to cycle the tool once will allow the new pressure to be the norm. (If this makes sense?)
Apr 06, 2014 | Air Tools & Compressors
Just purchased ar142 blue clean electric pressure washer....how do I adjust the spay?
pressure washer nozzle article may help:
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
Sep 07, 2013 | Blue Clean AR North America AR142 1600Psi...
Adjust water pump pressure
pressure control valves are non adjustable
They operate to unload the pump when the trigger is released
What can vary pressure is the jet size at the end of the wand
The screw and nut on the valve is only to regulate the stop/start pressure as the trigger is pressed/ released
low pressure at the wand jet can be from low water supply to the pump or pump internal problems
Feb 13, 2018 | Coleman Garden
I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
Mar 03, 2010 | Garden
Trying to remove rear brake drum cover,have already adjusted star wheel and still won't remove. what am i doing wrong? for a 93 plymouth grand voyager
  1. Raise and support the rear of the vehicle on jackstands.
  2. Remove the wheels and tire assemblies.
  3. Remove the brake shoe adjusting slot cover from the rear of backing plate.
  4. Insert a thin tool through the adjusting slot and hold the adjusting lever away from the star wheel.
  5. Insert an adjusting tool and back off the star wheel by prying downward with the tool.
  6. Remove the center hub dust cover, nut, washer, brake drum, hub and wheel bearings.
To install:
  1. Inspect the brake lining and drum for wear.
  2. Inspect the wheel cylinder for leakage. Service as required.
  3. Remove, clean, inspect and repack the wheel bearings.
  4. Install the brake drum and tighten the hub nut to 20-25 ft. lbs. (27-34 Nm), then back off the nut until bearing pressure is released.
  5. Retighten the nut finger tight, align the cotter pin hole and install the cotter pin.
  6. Adjust the rear brakes as described in the beginning of this section.
Removing the rear drum adjusting hole cover plug
Oct 07, 2009 | 1993 Plymouth Grand Voyager
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
NO PSI
have you checked to make sure that keyway is installed between electric motor and pump. also adjustment on unloader valve may be incorrect. If the big brass nut on the unloader is able to be turned by hand, then this is probably your problem (running pressure and spike pressure needs to be set and locked down using a pressure guage). does water come out of nozzle at all? if not, tip being stopped up may be the problem. trash between unloader ball and seat can also cause no pressure (usually caused by a burr left inside brass pieces during the manufacturing process). I have seen all the check valves stuck on a brand new unit from sitting on the shelf for so long, but this is usually the case with General Pumps.
Jan 07, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
