Question about ASUS Computers & Internet
I upgraded the OS of my loptop ASUS a9RP from window xp to window 7.The device driver for base system device has not been installed, its because the software included has an OS of window xp and I need the software Base System Device Driver compatible with window 7. Can you give me a copy of it? thanks!
    Brigadier General:
  • 8,909 Answers
Within Win7 Pro and Ultimate there is a in XP Mode. That would mean you can use your old driver howver, before that I would check on the manufacturers web site for your Base System for Win7 drivers. You may well find thet Vista drivers work OK.
Hope that helps.
Posted on Apr 03, 2011
No video after boot up
Ahem.
Driver: Small piece of software that allows the Operating System to communicate with a device.
The device in question is the graphics chipset.
The Operating System is now Windows 7 64-bit.
You were running Windows XP -> 32bit
(Have you got audio? Sound)
This is why I repeatedly try to tell people;
LOOK TO SEE IF DRIVERS ARE AVAILABLE,
before trying to upgrade to frickin Windows 7!
http://support.asus.com/Download.aspx?SLanguage=en&m=M4A785TD-V+EVO&p=1&s=24
Yes sir; sure are.
+ VGA (3)
Suggest use the oldest version -
AMD VGA driver V8 631.0.0
http://en.wikipedia.org/wiki/Integrated_circuit
The reason Windows XP blue screened is because the Integrated Graphics of the Asus M4A785TD-V motherboard couldn\'t handle the game.
You need a graphics card. A PCI Express graphics card inserted into the BLUE PCI Express x16 expansion slot, on the motherboard.
(Remember; Install the software F-I-R-S-T, then unplug from power, FOLLOW Anti-Static Precautions; and THEN physically install the graphics card.
Software; The Installation Disk for the graphics card.
Has the Drivers, and user interface.
User Interface: Catalyst Control Center for ATI graphics cards;
Nvidia Control Center for Nvidia graphics cards)
Regards,
joecoolvette
Dec 25, 2012 | ASUS M4A785TD-V EVO Motherboard
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
I have Installed Windows 7 ultimate but my video controller driver (VGA) can not be found. It does not allow me to install a VGA driver.
From the manufactures site, they only have VGA driver to support Windows XP. Did you upgrade your system from that OS?
It may work but if it doesn't, its best you downgrade back to xp. Here's the link for where to download it http://support.asus.com/download.aspx?SLanguage=en&m=Eee+PC+900HD%2fXP&p=20&s=1&os=29&hashedid=n%2fa
Aug 30, 2011 | ASUS Eee PC 900HD Netbook
How to returned my webcam on my loptop when my loptop is upgrade to windows 7 my webcam is lost. before is windows xp.
You have to download windows 7 driver for your webcam because it will not function if you did not install the driver for window 7. Check the brand name and model example a4tech, go their official website and search for the driver commonly you can download the driver by clicking the tab support or download. In case you can not find the driver for windows 7 you can not use your camera. In that case you need to buy a webcam that supported by windows 7 or has a driver for windows 7. Or downgrade your operating system to windows xp! Have a nice day!
Jun 08, 2011 | Computers & Internet
I am not able to download graphics of asus p5sd2-vm
http://support.asus.com/Download.aspx?SLanguage=en&m=P5SD2-VM&p=1&ft=3&os=29
Choose your OS, eg XP, Vista, Windows 7
If you are using Windows 7 download the Vista driver
If you are having trouble with the Global(DLM) link choose instead the Global or China links.
Apr 06, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I have missed my base system device driver after changing windows
You have mentioned that you changed the Windows OS but did not mention that which is the OS installed in the computer currently. For any OS, Base System Device error will show up in the Device Manager if Memory Stick Driver is not installed properly. The Memory Stick drivers are available for Windows Vista, 7 and XP for your computer model, please download and install the Memory Stick Driver form the Sony esupport website. This will resolve the issue.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCS320JW&SelectOS=34
Thanks!!!!
Dec 23, 2010 | Sony VAIO VGN-CS320J Notebook
I cannot install windows 7 on my p5vdc-mx motherboard, it keeps freezing on installation
Uodate the P5VDC-MX BIOS to version 0806. Download it from ASUS official site.
Aug 03, 2010 | ASUS P5VDC-MX Motherboard
I installed windows 7 os and my mother board drivers not support that os.help me.my mother board is asus p5rd1-vm. pentium 4 processor 512 ram
Come back on XP or Vista but XP works better.There is no driver for W7 yet.Motherboards manufacturers will provide drivers for W7 when Microsoft will announce that the system(W7) is ready to be sell....Windows 7 is still beta! If Microsoft still provide "UP DATE" for XP why you want to install other OS?
Mar 10, 2009 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
423 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
